-   -   I need help, montherboard! (http://www.hardwarecanucks.com/forum/cpus-motherboards/57555-i-need-help-montherboard.html)
fabiquest October 27, 2012 03:06 PM
I installed a new motherboard on my pc, and now ta that point mark and written Video Controller (VGA compatible), I already researched in several places and can not find ...
pow if someone could help me, Thank you in advance.
here is my motherboard.
I've tried several ways by cd, but it does not install at all, says nothing was found ...
I've tried manually and tb does not work
Motherboard Name Digitron: G41T-M7
Shadowmeph October 27, 2012 04:39 PM
I am only guessing at what you are saying is that the VGA on the motherboard isn't working?
botat29 October 27, 2012 04:41 PM
it's ECS who did that board, go there aND download the drivers for the onboard GPU
ECS Web Site > G41T-M7 (V1.0)
Rasparthe October 27, 2012 04:42 PM
The Video controller refers to your graphics card. If you don't have a graphics card installed then it is your onboard graphics. You should go to the website for your motherboard and download the VGA or your graphics card website and download the drivers there.
fabiquest October 28, 2012 08:24 AM
Rasparthe, the site of the manufacturer no longer exists ..
botat29, this link is not for XP, I'm not lying ..
ECS Web Site> G41T-M7 (V1.0)
nasrott October 28, 2012 08:47 AM
there is a vga link in the download section from botat29's posted link for 32 or 64bit winxp
Rasparthe October 28, 2012 10:28 AM
I don't think that it is a ECS motherboard, or at least his original post states that it is a Digitron, which is a Brazilian motherboard manufacturer. But if the board is using an Intel G41 chipset you can download the VGA drivers right from Intel. What does CPUz say the chipset is?
fabiquest October 28, 2012 12:47 PM
I've installed and always says the system did not meet the minimum requirements ...
nasrott October 30, 2012 04:23 AM
download CPUID - System & hardware benchmark, monitoring, reporting as suggested and copy and paste the results for the motherboard tab into a post
fabiquest October 30, 2012 09:48 AM
Link CPUID, board; http://img217.imageshack.us/img217/3614/17010781.png
