Originally Posted by nasrott |
Exactly as stated above. Your original post gives the wrong motherboard and perhaps the reason you are having trouble getting the drivers to install. The CPUz states your motherboard is a G31T-M7, and runs a different chipset/VGA than the one you originally stated.
You can likely download it directly from the link that Nasrott gave but I like to download from Intel directly but it should be fine.
Here is a link for your onboard VGA drivers from Intel based on the fact you are using Windows 7.
