Old October 27, 2012, 12:49 PM
Default Case open Switches?
I have a bit of an issue.
It appears as though the board in my sig (the Q35T AM) is an old acer board, now from what I gather there was a Chassis Intrusion switch installed in the original case, and now without the switch the mobo is throwing me a warning on boot and I have to hit F1 to carry on.
I have checked the BIOS and can't seem to find any way to turn off the warning, but I can find a disable option for that and it doesn't seem to work. There is a jumper on the leads where the switch should be, even tried to remove it, is it that I need to have said switch or something else?
| MSI Z97 G45 Motherboard |
| Intel i7 4790K @ 4.00 GHz |
| Corsair H60 AiO Cooler |
| 16GB DDR4 G.Skill RAM |
| 2x Samsung 850 Evo in RAID0 |
| Samsung 840 Evo Series SSD |
| EVGA 1080 SC ACX 3.0 |
| Corsair 650W PSU |
| Razer H440 |
| 6x Corsair SP120 120mm Fans |
Heatware Record | Ebay Record
Old October 27, 2012, 05:00 PM
NyteOwl's Avatar
Normally intrusion switches are "Normally Closed" type. That is, when the case is shut the switch contacts are closed. WHn the case is openes so are the switch contacts. That's why you use a jumper when there is no swich installed. Not all BIOS have an entry for the CIS but with the jumper closed it should be the same as the chassis being shut anyway.
Have you tried resetting the BIOS back to defaults and see if it stops the alert?
Obsolescence is just a lack of imagination.
Old October 27, 2012, 09:48 PM
Yep, I cleared the CMOS and it did work once but on the second boot it threw the error again.
| Corsair 650W PSU |
| Razer H440 |
Old October 28, 2012, 07:50 AM
lowfat's Avatar
Is there an option under intrusion switch to reset?
Mael
Big Lian Li
Forever Alone
Old October 28, 2012, 12:26 PM
Yes, there is Disabled, Enabled, and Clear, but its always disabled and clear doesn't work lol, I don't get it.
| Corsair 650W PSU |
| Razer H440 |
Old October 28, 2012, 04:25 PM
Get a bag of jumpers and just close that switch. You mentioned in another thread that this board was dead then came back to life, so don't expect too much.
https://ca.startech.com/Computer-Par...-100~JUMPER254
Old October 28, 2012, 09:46 PM
I don't actually think the board was bead seeing as how I can't find anything physically wrong with it.
| Corsair 650W PSU |
| Razer H440 |
Open case martin_metal_88 Cases 6 September 21, 2009 12:53 PM
open air case suggestions gingerbee Cases 5 March 28, 2009 05:57 AM
Antec new open concept case. TopDogZero Cases 8 June 5, 2008 05:56 PM
