  #31 (permalink)
Old October 23, 2012, 09:52 AM
Goin further on my recent xbitlabs review read .... it looks like a 8350 will get you anywhere from a 4.7-5 ghz range on a multi oc & possible voltage tweaking for overclocks on air so far ...
  #32 (permalink)
Old October 23, 2012, 10:10 AM
Question on your test methodology: Setup used an M4 SSD but in point E it says you defragged them after all programs were installed/updated? I was under the impression that defragging an SSD was a bad thing? Is that just something that carried over from the template of older tests?
  #33 (permalink)
Old October 23, 2012, 10:28 AM
Soultribunal's Avatar
Almost for certain was a carry over, which sometimes gets missed when Platforms change. I'll poke him to fix it.
-ST
  #34 (permalink)
Old October 23, 2012, 10:31 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Simply carry-over. Totally my mistake.
  #35 (permalink)
Old October 23, 2012, 11:02 AM
Arinoth's Avatar
Based on this, you can consider the overclock as stable.
Looks like you could be keeping an all AMD systems for a while then after this eh?
  #36 (permalink)
Old October 23, 2012, 11:31 AM
Mena's Avatar
Very impressive overclock but I am confused...
It this an actual eight core cpu or is it really four real cores and four virtual core?
I am watching you.
For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.
When a ladder was stolen from a store the manager said that further steps would be taken
  #37 (permalink)
Old October 23, 2012, 11:34 AM
SKYMTL's Avatar
The Bulldozer architecture uses a very different approach. It uses four "modules", each of which contains two x86 processing engines but those don't necessarily equate cores as their resource distribution is quite different. Basically, to answer your question, it is neither but it is both.
  #38 (permalink)
Old October 23, 2012, 11:49 AM
Great review and thanks for for putting in your time to do it :)
Comp1 (Mine) : ASUS Sabertooth, i7 2700K, 8GB 2133 GSkill, XFX 7970 DD, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : Intel DP67BG, i7 2600K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, Sapphire 7950 OC, Corsair 950W, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Sapphire 7970, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 1200
  #39 (permalink)
Old October 23, 2012, 12:08 PM
I can honestly say that there might be a light at the end of the tunnel now.
Massive Driver Patch. Better than expected (from me) piledriver performance.
Late to the party, but at least you've dressed well for a change AMD.
-ST
  #40 (permalink)
Old October 23, 2012, 12:11 PM
Nice review as always. Good to see its a step in the right direction. A drop to 22nm and this would be good to go for nearly everyone(put power consumption in check), but pricing seems to help that figure out. Look forward to your follow on review.
Anyone upgrading to this have a 1090t they want to part with cheap to drop in my AM2+ board?
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
GTX 660 Ti Review Comment Thread SKYMTL Video Cards 147 September 15, 2012 11:45 PM
Vishera FX 8350 yehia7000 CPU's and Motherboards 7 August 8, 2012 08:40 PM
BFG GTX 285 OCX Review Comment Thread SKYMTL Video Cards 8 January 21, 2009 01:55 PM
BFG GTX 260 Review Comment Thread SKYMTL Video Cards 33 November 15, 2008 10:26 PM
