  #101 (permalink)
Old December 15, 2012, 06:16 PM
sa seba's Avatar
I did it. Couldn't help myself.
I have the 8350 running at 4.5GHz with a H80i on quiet, bumped the core voltage up to 1.380 and it's running nicely.
  #102 (permalink)
Old December 16, 2012, 02:11 PM
Very nice , currently @ 4.6 @ 1.4v on mine. Still tryin to do some more scaling/testing based on wot's
  #103 (permalink)
Old December 17, 2012, 06:25 PM
sa seba's Avatar
What temps do you get on full load with your hyper 212?
I am getting up to 53 celcius after an hour of prime. The H80i seems less effective than I thought.
  #104 (permalink)
Old December 17, 2012, 06:46 PM
botat29's Avatar
Get mine yesterday I push it at 5120 with the cores at 1.524 56'C under OCCT EK supremacy , in the garage, room temp of 17'C
  #105 (permalink)
Old December 17, 2012, 08:09 PM
sa seba's Avatar
Hm, I think I just experienced... e-shrinkage.
Will try some more later with my measely H80i.
  #106 (permalink)
Old December 24, 2012, 12:25 AM
So far i thought i was doing 4.6 .... but it seems like anything over 4.4 i get lockups at odd times like accessing the net thru another browser window?
Im honestly at a point in time that I am not shure if i had a dud for oc'ing chip or if maybe its a motherboard limitation or something else at this point in time ..
  #107 (permalink)
Old December 27, 2012, 06:10 PM
sa seba's Avatar
How about a fresh and barebone windows install without flash and the such to eliminate any 3rd party fuckery?
Adobe Flash used to give me some nice lock ups.
  #108 (permalink)
Old December 27, 2012, 08:55 PM
EmptyMellon's Avatar
Arrow
terrybear, I might have missed it, but looking over your past relevant posts (to this issues), I have not seen you listing your mobo's BIOS version. At the moment the revision is at 1604 (for the ASUS M5A99X Evo - ASUS - Motherboards- ASUS M5A99X EVO), I would highly recommend for your to flash your BIOS and other relevant mobo subsystems (Audio, Chipset, LAN) for a good measure. In my experience, my M5A99X Evo did become more stable during the occasional OC, even though I don't push mine into the extremes plus I am still running a 1090T.
  #109 (permalink)
Old December 28, 2012, 12:01 PM
I am running the 1604 bios yes ....
I have so far figured out the locking up was occuring cause of as you mentioned sa, flash ... i re-downloaded & installed the latest one & the issue of lockups has been resolved.
Currently 4.5 ghz 22.5x multi @ 1.4v's (fluxuates around 1.39v) ...... Heats never the issue, never seen it in game testing or "catzilla" go over 42c ..
  #110 (permalink)
Old January 6, 2013, 02:59 PM
Default Update
So, after deciding to tweak the load line settings from auto/100% to 110% Im now stabilily @ 4.6 ghz @ 1.4v (varies 1.38-1.392 in cpu id).
Will try pushin it higher in awhile ... but happy with it at its current clocks.
GTX 660 Ti Review Comment Thread SKYMTL Video Cards 147 September 15, 2012 11:45 PM
Vishera FX 8350 yehia7000 CPU's and Motherboards 7 August 8, 2012 08:40 PM
BFG GTX 285 OCX Review Comment Thread SKYMTL Video Cards 8 January 21, 2009 01:55 PM
BFG GTX 260 Review Comment Thread SKYMTL Video Cards 33 November 15, 2008 10:26 PM
