Old April 21, 2008, 09:35 PM
Mulder's Avatar
Default Build Advice
I am looking to make an upgrade from my old amd 64 3700 system to a Quad core system. I was thinking of picking up a Q6600, 4 gigs of DDR2 (not sure of brand or speed) and a 750i or 780i motherbaord (or any motherboard that will support 45nm quad cores) then down the road i could swap the Q6600 out for something more powerful. I am also not sure if i really need SLI or not.
Already have
Full tower Case
Power supply OCZ PowerStream OCZ600
Video 8800GT
HD Seagate Barracuda 500GB
Monitor Philips Brilliance 202p
Needed
Quadcore Cpu (Q6600?)
Ram Mushkin XP PC2-8000 Redline
Motherboard (780I?)
Old April 22, 2008, 03:30 AM
sswilson's Avatar
Did you have a ballpark budget in mind, and are you going to be overclocking?
Welcome to Hardware Canucks BTW!!!
Old April 22, 2008, 05:02 AM
encorp's Avatar
I did months of research on my recent build. I ended up going with the 750i, it's a really solid board. I just didn't see the need for myself to go with a 780i over it, given the price and the added features I wouldn't use. The ram I ended up choosing was Mushkin Redline DDR1000 - REALLY nice stuff btw, and I price matched 4 gigs on NCIX.com and got it for 129.99! See here:
http://www.ncix.com/products/index.p...acture=MUSHKIN
I went with a Q6600 because I received it free of charge from a buddy at Intel and it is fantastic. There has been a price drop on some Intel chips though since I got mine together so you might want to check it out. Q6600 is an awesome option but you may be able to pick up a Q9450 if it's in your price range, I probably would have had I bought the chip myself.
Just my 2 cents!
Old April 22, 2008, 06:57 AM
Mulder's Avatar
I don't have a set dollar value budget persay but i would like to keep this purchase as reasonably priced as possible. I wouldn't mind doing some overclocking.
That Mushkin PC2-8000 looks good, thanks encorp. will take another look at the cpu prices aswell.
Old April 22, 2008, 07:01 AM
encorp's Avatar
Here's a link for that mem at 129.99 Canada Computers - Memory > Desktop Memory > DDR2 800 PC2-6400+ : Mushkin XP PC2-8000 Redline 4GB 2X2GB DDR2-1000 CL5-5-5-12 240PIN Dual Channel Memory Kit.
You could either order it from there, or if you're using NCIX.com you can price match it with that link.
There's a couple forums posts by me over in the RAM section where a bunch of the HWC guys discuss it, plus a hefty review as well on these forums :)
Old April 22, 2008, 07:15 AM
Mulder's Avatar
Thanks a lot for info and the pricematch link encorp, I'll head over to the Ram section and give those threads a read asap. I'll be ordering from NCIX as I've had nothing but amazing service from them in the past.
Old April 22, 2008, 07:37 AM
Synth's Avatar
eVGA 750i SLI For the Win (that is actually the name of the board), check it out, great reviews. Lowest price @ DirectCanada.
Old April 22, 2008, 02:48 PM
Mulder's Avatar
what about the intel cipset boards? could i possible get something that would be a little cheaper then the nvidia boards that would allow for modest overclocks? if i could save some on the board I could more then likely purchase a Q9450.
Old April 22, 2008, 03:10 PM
SugarJ's Avatar
Giga-byte GA-P35-DS3L $89.99 at NCIX
Great board for single GPU single HDD config. OC's very easily.
http://www.ncix.com/products/index.p...e&promoid=1008
Old April 22, 2008, 03:21 PM
Cptn Vortex's Avatar
Yeah +1 for the DS3L board. Such a good price, and a great little board.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
