<~----> Mid range mobo with wifi? - Hardware Canucks
Old October 12, 2012, 02:27 AM
Default Mid range mobo with wifi?
Any recommendation? Or a good PCI solution?
EDIT: PCI/PCIe, Z68/Z77/H77, mATX/ATX
EDIT 2: So basically I'm helping my friend build a new gaming system but he's on a tight budget. I can't seem to find a mid ranged mobo that comes with wifi. & I have no experience in wifi solutions.
Old October 12, 2012, 04:09 AM
WhippWhapp's Avatar
Get an Alfa, why are you limiting yourself to onboard or pci-e?
I rub and whack and choke and stroke!
Old October 12, 2012, 06:54 AM
Pabz0r545's Avatar
Have you looked at any of the Z77 itx motherboards?
I kicked the habit...
Old October 12, 2012, 07:24 AM
No idea, more reliable perhaps?
Nope I'm looking for either mATX or ATX mobo
Old October 12, 2012, 09:36 AM
Why don't you just buy a regular mATX or ATX mobo and then add a usb/pci-e/pci wifi device? It would come out cheaper since you then have any choice based on price.
That's what I'd do. Check shopbot.ca out and buy the cheapest Z68/Z77/H77, mATX/ATX board out. Asus, Biostar, MSI,
E75 - $70: Newegg.ca - ASRock B75M-DGS LGA 1155 Intel B75 SATA 6Gb&#47;s USB 3.0 Micro ATX Intel Motherboard
B75 - $80: Newegg.ca - BIOSTAR B75MU3&#43; LGA 1155 Intel B75 HDMI SATA 6Gb&#47;s USB 3.0 Micro ATX Intel Motherboard
TZ75 - $110
Newegg.ca - BIOSTAR TZ75B LGA 1155 Intel Z75 HDMI SATA 6Gb&#47;s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Asrock Z77
ASRock Z77 EXTREME3 ATX LGA1155 DDR3 3PCI-E16 1PCI-E1 2PCI SATA3 DVI HDMI D-Sub USB3.0 Motherboard
But, go on shopbot and compare. I think they'll all be relatively the same (similar enough) and for just (budget) gaming, you need a decent video card and fast cpu.
Old October 12, 2012, 11:30 AM
crowTrobot's Avatar
Don't base your decision of a motherboard on the WiFi functionality!
USB WiFi is really cheap. I have a pair of MSI USB Wireless N adapters that were $8 bucks each and work very well. Literally just plug and play to the USB port, no drivers needed. No WiFi experience needed too (just WiFi signal).
Old October 12, 2012, 04:03 PM
WhippWhapp's Avatar
Plus the fact that the tower might not be in a place that facilitates good reception... really get a 1000mW Alfa, pair it with a usb extension/repeater cable, and add an antennae if you want.
Tags
wifi motherboard pci
RDC over local Wifi vs remote wifi vs 3G Generic User #2 O/S's, Drivers & General Software 3 January 23, 2012 07:14 AM
Is my mobo messed again? (ASUS M2N32-SLI Deluxe Wifi) Scart Troubleshooting 1 December 23, 2008 01:51 PM
Satellite dish + biquad antenna = extended wifi range Mibs Peripherals 1 July 12, 2008 07:09 AM
Asus P5K Premium wifi mobo problem kruzn4evr CPU's and Motherboards 5 July 4, 2008 12:28 PM
Best BIOS Setting for Mobo P5K-E Wifi PaxeSalute CPU's and Motherboards 2 March 21, 2008 03:48 PM
