Old October 11, 2012, 11:07 AM
On a similar note, if there's no Vishera-specific motherboard, how will you know if the motherboard you get for a Vishera has the correct BIOS revision to accept the new CPU if you don't have an existing AM3 to flash with?
Old October 11, 2012, 11:31 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
990FX + Bulldozer = BIOS update possible (already AM3+ compliant)
990FX + AM3 Phenom, Athlon, etc. = BIOS update possible (has an AM3 processor installed)
Buy new 990FX board w/o update Piledriver microcode = Will boot into BIOS due to Bulldozer compatibility.
The main thing to remember is that ALL Bulldozer-capable boards will support Piledriver. The microcode update is simply to ensure optimal performance.
Old October 11, 2012, 01:46 PM
Ah that's good to hear - I thought it was like the AM2 days where the motherboard would send ridiculous voltage and blow up either the CPU or its own VRMs.
Old October 11, 2012, 07:19 PM
Avenger212's Avatar
Originally Posted by SKYMTL View Post
The answer is...no.
Most 990FX motherboards already support Piledriver's microcode with their newest BIOS files. PCI-E 3.0 is certainly not necessary.
Originally Posted by terrybear View Post
Simply put no.
There where reports/info that 10xx series chipset is being pushed back to a 13' timeframe. Futher rumor was steamroller was gonna be pushed out with the 10xx series chipset ... but word is nor AM3+ will also suposivly do steamroller as well.
My guess the reality is as well with DDR4 becoming so close to market that 10xx series chipsets are being held back to make a change over to DDR4, possibly Sata Express (double to quad pumped Sata interface) & other things.
Remember for awhile AMD (well mainly Ati at the time) did have a powerful chipset that ran on both intel/amd cpu's & where seen that the cpu's itself where what held the chipsets back from seeing there full power potential. To me ... this is what I feel amd needs to do in combination with the cpu side of things to bring some competition back to intel.
Thanks Sky and Terry, that was the answer(s) I was looking for. It seems I will stay with my 990FX for a while and see what happens to Piledriver after it's release.
Originally Posted by great_big_abyss View Post
OP, you seem to attach a negative connotation towards not having a chipset. I assure you, it's good news. All of us (myself included) who bought 9-series chipset motherboards and then upon seeing reviews did not upgrade to bulldozer (choosing instead to run our existing phenom IIs) will be able to simply drop in a new Vishera chip...depending on reviews, of course.
I do hold a grudge against the 990FX, cause I bought my Crosshair Motherboard in the hopes that Bulldozer was a successful product. But instead I did not continued to buy Bulldozer after seeing the difference against my Phenom II.
Truth to be told I was just actually interested whether there is going to be a new chipset for Piledriver.
Old October 16, 2012, 07:46 AM
SKYMTL's Avatar
Which features are you referring to?
Old October 16, 2012, 10:57 PM
The motherboard manufactures can't just incorporate those features? Also, I don't think any particular brand has been ahead due to overclocking, maybe some small advantages but every brand has boards that support overclocking.
Tags
amd , asus motherboard , intel
Motherboard Manufacturers Expected to Show X79 at Computex 2011 FiXT Press Releases & Tech News 6 May 30, 2011 07:03 PM
LucidLogix Releases Virtu GPU Virtualization Software to Motherboard Manufacturers FiXT Press Releases & Tech News 1 February 22, 2011 08:45 PM
EK is going to release EVGA Classified full cover chipset block Dazmode Water Cooling 14 June 17, 2009 07:16 PM
Trying to choose a motherboard/chipset bmfmass CPU's and Motherboards 14 November 21, 2007 04:24 PM
Intel to release new P35 chipset in April or May Babrbarossa Press Releases & Tech News 0 March 15, 2007 11:31 AM
