Old October 8, 2012, 10:13 AM
JD JD is offline
Yup each SAS connector can support 4 SATA drives without anything else.
Old October 8, 2012, 10:48 AM
MARSTG's Avatar
yes I had a SAS controller once doing raid 0, SATA drives work fine on SAS controllers but SAS drives do not work at all on SATA controllers. I think that card will do the job just fine.
Old October 8, 2012, 11:13 AM
NyteOwl's Avatar
RAID isn't about backups, it's about keeping the system running in the event of a drive failure by providing drive redundancy (which is why RAID 0 is a serious oxymoron).
The two cards I mentioned will also run in JBOD mode (just a bunch of disks) so you can use it as just a multi-drive controller if you wish.
The Supermicro is a decent card for its type though there are some reports that the Marvell controller is slower than LSI's. It is also a SATA II not a SATA III controller.
Obsolescence is just a lack of imagination.
Old October 8, 2012, 01:39 PM
MARSTG's Avatar
Originally Posted by NyteOwl View Post
...there are some reports that the Marvell controller is slower than LSI's. It is also a SATA II not a SATA III controller.
Do you know any mechanical HDD that is bottle-necked by the transfer rates of the SATA II specs? Me I don't, so this is a moot point here.
No M-ITX boards with 3 or more SATA 6Gb/s connectors? Stosh CPU's and Motherboards 11 May 3, 2012 04:51 AM
Help with chassis/power fan connectors on motherboard Gary Seven New Builds 4 March 3, 2012 11:33 PM
Full usb 3.0 and sata 6 Motherboard? Blu CPU's and Motherboards 7 January 12, 2011 11:25 AM
Not enough sata power connectors book0006 Storage 5 January 13, 2010 11:46 AM
Seeking MB's that have more than 4 SATA connectors antonin Storage 9 April 1, 2008 11:31 AM
