Old October 5, 2012, 11:51 AM
Trial Member
Default Help with mobo choice
I'm building a new computer (haven't done that in 20 years) based on i5-3450k with HD4000 graphics and SSD. I am not a gamer but I want a computer that is fast with USB3 and SSD. I would not install a graphics card for a while.
I was considering the gigabyte GA-Z77-DS3H or the asus P8Z77-V lx. I'm having a hard time deciding which to use. Don't want to spend a fortune (don't want to go ultra cheap either) but want a good board that is easy to setup.
Any help appreciated,
George
Old October 8, 2012, 02:02 PM
MARSTG's Avatar
The Asus board has that Q connector that makes attaching the cables to front panel a lot easier : like the power, reset, hdd light. None of the boards have VRM cooling however. Asus board has better placements for the SATA ports, 2 PCI E x16 ports, in case you want to install a RevoDrive to make it lightning fast. I would go with the Asus board.
Which one is a better choice? BootlegUsher Power Supplies 4 December 21, 2009 03:04 PM
860 MoBo Choice - Need Some Opinions UnknownSoldier CPU's and Motherboards 35 November 30, 2009 09:58 AM
which is these is the best choice for me Bobobear New Builds 14 November 27, 2009 05:58 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
Trying to make a mobo choice... Rausch CPU's and Motherboards 10 February 6, 2008 07:05 PM
