Old October 4, 2012, 11:46 AM
Default bsod problem
I have asus sabertooth z77 and i7 3770k at its stock and when i played video at utube the computer shows me blue screen suddenly ,I have the latest bios for this board 1504 and have the latest driver for my vga card ,I dont know what is the the main cause of this problem so i Appreciate every one help me .
Old October 4, 2012, 12:10 PM
Bloodystumps's Avatar
what is the BSOD code that comes up and does it say on the BSOD a particular driver that is to blame? I had that with my CHIVE and it turned out to be the Intel NIC driver , mine BSOD only happened when I watched youtube or heavy network load .
Old October 4, 2012, 12:20 PM
how can i get this cod and where ?????
Old October 4, 2012, 12:52 PM
bottom of the Blue screen
the top of the screen you will see "the problem seems to be caused by the following file "<---- that is a good place to start to look
Old October 5, 2012, 06:46 PM
here's some common ones if you're overclocking
BSOD codes for overclocking
0x101 = increase vcore
0x124 = increase/decrease vcore or QPI/VTT...have to test to see which one it is
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1E = increase vcore
0x3B = increase vcore
0x3D = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too Much memory voltage
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
0x7E = Corrupted OS file, possibly from overclocking. Run sfc /scannow and chkdsk /r
see hexdec number after stop: 0x00000050 just catch the last 2 or 3 of that and shorten to 0x50
on a 1155 SB its
they might specific to a socket 1155 and sandy bridge tho
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
Old October 6, 2012, 07:43 AM
i downloaded windows debugging tools and it says probably caused by ntoskrnl.exe
Old October 6, 2012, 08:11 AM
dandelioneater's Avatar
Could be that ntoskrnl.exe is corrupt or maybe there could even be some malware on your PC. If it is indeed ntoskrnl.exe that is the issue, check out this: "ntoskrnl.exe" BSOD - Windows 7 Forums
Steam connection problem (Problem Fixed) great_big_abyss Gaming 3 January 10, 2012 05:37 PM
BSoD Problem PH93 Troubleshooting 24 June 23, 2011 04:29 PM
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 07:01 AM
Getting BSOD! someone please help me solve the problem flytothesky Troubleshooting 1 September 15, 2010 11:58 AM
4850 CF BSOD/Crashing Problem derrXIII Video Cards 6 October 10, 2008 03:17 PM
