Old October 4, 2012, 11:34 PM
There's an Asus P8P67 in the FS section.
Old October 5, 2012, 01:22 AM
I'd say get the GPU, how can people be saying a stock i5-2500k is a bottle neck already, I get full usage or just about on both 6950s plenty of times in certain games, and I use v-sync
I play close attention to my usage over the next couple of days. Soon I plan to rock a 79x0 CF or a 670 sli, I don't expect any noticeable CPU bottleneck
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
Old October 6, 2012, 09:34 AM
Thanks TedShackley - it'd be interesting to see that, although task manager isn't smart enough to really show if you're bottlenecking one core (which is often the case).
As an update, I swapped my coolers / fans around with a Scythe Gentle Typhoon on my 2500k's GeminII with a 40mm fan at full speed pointed straight at the VRMs. I also swapped the P180's top fan around to use as an intake, to bias towards feeding fresh air to the CPU (and probably raising temps somewhere else in the case). (Yikes this is loud ) With this less-than-subtle setup it looks like I can easily reach 3.8GHz with IntelBurnTest running, or 3.9GHz with BOINC crunching.
I should easily be able to keep 3.8 GHz stable, or at least 3.7 GHz on 4 cores instead of just 1 with this. I guess I can thank AMD faildozer that 2500k at 3.7-3.8 GHz won't be a major bottleneck for gaming for at least another year
Motherboard and ram for the 2500k tt74Rocky New Builds 9 July 10, 2012 11:22 PM
Core i5 2500K + MSI Z77 Motherboard Good? geokilla CPU's and Motherboards 3 April 15, 2012 03:46 AM
trying to get the most out of GTA4 with i5-2500K OCing TedShackley CPU's and Motherboards 3 January 25, 2012 08:50 AM
Motherboard under 100 bucks but good for oCing? lanken123 CPU's and Motherboards 10 October 1, 2008 01:44 AM
Best OCing motherboard death_hawk CPU's and Motherboards 19 July 7, 2008 09:36 AM
