Old September 29, 2012, 08:21 PM
Default CPU Advice
I'm currently running on my Core i7 920 D0 Stepping @ 3.2Ghz & Asus P6T Deluxe V2.
Should I be looking to upgrade it to 6 Core 970 or better?
or
Should I be making the switch to Sandy/Ivy Bridge?
Benefits/Drawbacks would be appreciated!
Old September 29, 2012, 08:42 PM
An OC'd Nehalem is still a strong processor, although Sandy/Ivy give better performance per watt.
We'll need to know what you want to do with your CPU before answering that. If your purpose is gaming,
then which games you play and what GPU you use will be important as well.
Old September 30, 2012, 11:27 AM
GT7R's Avatar
If you can get a good price on the 970 then go for it, I would. Then upgrade when Haswell, because 1155 is edging towards it's EOL.
Old September 30, 2012, 12:15 PM
supaflyx3's Avatar
I would say try pushing the CPU to 4Ghz and see if you're satisfied. But if you do a lot of media work an upgrade to a 970 would be a good idea.
Old September 30, 2012, 12:22 PM
dandelioneater's Avatar
A 4.0 GHz i7 is still a potent chip for games and most anything else. A 970 would only be worthwhile if you do encoding or run applications that can utilize the additional 4 threads.
Old October 1, 2012, 06:38 AM
486's Avatar
486 486 is offline
No need. Wait for Haswell.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old October 1, 2012, 11:44 AM
I would say OC and wait for a platform upgrade.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old October 1, 2012, 12:20 PM
just be warned overclocking that cpu is going to dump a lot of heat and require a good cooler.
Old October 1, 2012, 01:15 PM
NyteOwl's Avatar
Lots of mileage still left in that processor unless you actually need the extra cores/threads for a special purpose.
Obsolescence is just a lack of imagination.
Old October 8, 2012, 03:12 PM
like video processing or Folding@home
Advice mchutch Water Cooling 14 January 27, 2012 05:25 PM
Fan advice Kilauea Air Cooling 3 October 15, 2009 04:59 AM
OS advice... somecanadianguy O/S's, Drivers & General Software 18 October 9, 2009 08:20 AM
Need some advice... JD Water Cooling 29 May 4, 2009 06:21 PM
New Rig Advice darren700 New Builds 10 October 30, 2008 02:55 PM
