In the real world, in an office setting where the server is basically controlling the network for 10 machines and acting like a file server, does it make any difference if the motherboard has 1 CPU or 2, does it make any real difference if you go with Xeon X3s or X5s, 2011 or 1155 chipsets? do you even need a server motherboard or will a normal motherboard work just fine? what does the "server" motherboard get you that a "normal" motherboard doesn't (other than the possiblility of dual CPUs)? How does dual LAN ports help you? What is the expected bottle neck in network speed response (the hard drives?)? I guess I am asking all these questions since I am not sure that the added cost of dual CPUs etc will make the system as a whole work any faster. Thoughts out there from people who do this for a living?
I have built a number of new workstations for the network and now I am looking at the server which is old and noisy. It works fine but I have an urge to tinker with it. Not sure if upgrading will be of any benefit other than a learning experience.
also can you use SSDs in a hot swap RAID configuration? (getting back to the what's the slowest part of this whole system question). the workstations have 1Gb ethernet ports and CAT 5e and 6 cables and a Gb router.
Or should I leave well enough alone since it is more complicated than a workstation, or should I buy a server already put together that one will assume will work when it arrives.
