Old April 29, 2008, 04:12 AM
ipaine's Avatar
Since you mentioned that the TRUE won't fit, one that is smaller that works great on my q6600 is the arctic cooling freezer pro 7. I have my q6600 running at 3.0GHz and it keeps my mine nice and cool.
@sswilson
You can run the memory at less than 1:1 with an Intel chip, well at least with my board. I have the Asus P5N-E SLI and I have the option to run the ram linked to the FSB or unlinked. When it is linked I have various settings for the ram, such as sync mode, 3:2, 5:4, and 1:1. Unlinked of course means you can set the ram totally independent of the FSB. Just not sure if those options are available on the board he is considering getting.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old April 29, 2008, 07:05 AM
sswilson's Avatar
@sswilson
Yes you can do it with Nvidia chipsets, but not with intel chipsets.
Old April 29, 2008, 10:43 AM
ipaine's Avatar
Makes sense, I wasn't even thinking about that. Not to mention now I read what you wrote and see that you did say chipset in there. Well thats what happens at 5am, just too early to read.
Old April 29, 2008, 11:12 AM
Cptn Vortex's Avatar
I used to have that same case! Made carrying it around nice and easy
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
