-   -   hyperthreading useless in gaming? (http://www.hardwarecanucks.com/forum/cpus-motherboards/56760-hyperthreading-useless-gaming.html)
aznb3nms September 16, 2012 10:00 PM
HYPERTHREADING IS USELESs IN GAMING?
meaning, buying a pentium is no difference from i3 if put in gaming situations?
Silent_Avenger September 16, 2012 10:12 PM
Yea pretty much unless the game can actually take advantage of the HT feature take a look at this graph:
http://media.bestofmicro.com/J/K/348...PU%20Cores.png
from: http://www.tomshardware.com/reviews/...rk,3268-7.html
You can see the pentium is right near the i3 in GW2.
Dzzope September 17, 2012 12:44 AM
Totally depends on how many threads the game is designed to use.
Anything that is single threaded will see 0 difference.. 2 threads MAY see some slight improvements as you will have other processes running at the same time etc etc.
Anything that can use 2+ threads will see a difference (depending also on how cpu intensive it is)
Bond007 September 17, 2012 03:25 AM
Depends on the game and how it is designed to run. Generally speaking you are right that hyped threading does very little in games. However, I am sure there are some games designed to run 4 threads that would run better on i3 than pentium. Generally games are not optimized for more than 4 threads.
frontier204 September 17, 2012 05:24 AM
HT between the G850 and i3 can help in some games:
Intel Pentium G850, Pentium G840 and Pentium G620 Review. Page 4 - X-bit labs
http://www.tomshardware.com/reviews/...mark,3120.html
When you start thinking i5 vs i7 however the difference is much less (to the point where 100MHz of overclock would be more noticeable), but with dual cores the difference is there. If I was in the market for a low-end gaming machine I'd probably go for this or wait for AMD's Piledriver CPUs to hit the desktop:
Newegg.ca - Intel Core i3-3220 Ivy Bridge 3.3GHz LGA 1155 55W Dual-Core Desktop Processor Intel HD Graphics 2500 BX80637i33220
486 September 17, 2012 01:35 PM
HT may help or hurt, depending on thread affinity. So, case by case bases, but generally there is a trend in compilers to increase thread affinity.
ZZLEE September 17, 2012 02:26 PM
My fathers computer is a Asus P5Q with a P4 3.0 and and an 8600 GPU. passive cooled
Its Its hypertheaded more by acadent than design at the time.
It also has XP 32
Works fine fore him. He does Photos and Email and document printing mostly
What he does could all be done on laptop, and wants to Buy one
Only problem is he wants USB 3, BluRay, and a Nvidia graphics card
But he doesn't want to spend lots of money.
So my point is if you want a laptop ...
1erCru September 18, 2012 10:58 PM
Hyperthreading increases temperatures, but does turning it off actually increase stability as well, ignoring temps as a variable for the sake of argument.
As a game ever taken advantage of hyperthreading?
On2wheels January 30, 2015 07:21 AM
There's been alot of talk lately about why Dying Light runs so differently on everyone's systems. Techland asked people to send them their game log files and a dxdiag report. When I sent mine in I noticed this line about HT: Disabled, here's the top of the log file:
{03:21:09.263} INFO: [Game] > System locale is 'En'
{03:21:09.303} INFO: [Game] > Speech locale is 'En'
{03:21:09.333} INFO: [System] > Build version: 6.2015.0126.1708
{03:21:09.333} INFO: [System] > [PID] 1824
{03:21:09.523} INFO: [System] > [CPU] vendor: GenuineIntel, features: SSSE3 SSE4.1 SSE4.2 AVX F16C CX16 POPCNT HTT, clock frequency: 3400.13MHz
{03:21:09.523} INFO: [System] > [CPU] CPUs: 1, Cores: 4, HT: Disabled, Logical processors: 4
{03:21:09.553} INFO: [JobManager] > TM32e3e620, dedicated worker threads: 1 + 2, num cpus: 4
When I check CPU usage on Afterburner when I quit the game, one core is usually 100% while the other 3 are anywhere from 50-80%. It's an i5 3570k. Can someone explain if this is a game limitation or should hyperthreading be turned on for modern games?
ZZLEE January 30, 2015 07:39 AM
HT is much more utilized in game development these days.
Do essentially a bench pick a section of the game to run through HT off then HT on.
Many game now days can benefit from more threads.
