Old September 13, 2012, 04:22 AM
botat29's Avatar
Originally Posted by terrybear View Post
.... 90%+ proof
they are not such thing as 90%+ proof ................ 87.5° proof is 50% . same mistake with peroxide , 30 volume is 10%
The impurity in 50% iso is only water. the rubbing alcohol is the one to avoid as it contain stuff like camphor.
the 50% alcohol with Scott towel will do fine, remove most of it in one shot and finish with a second piece of paper towel
Old September 13, 2012, 05:58 AM
Soultribunal's Avatar
I'd avoid the q-tips as they tend to leave bit's of themselves behind. Beyond that the 90%+ ISO Is good, and use something like Microfibre cloth (or my personal favorite, I use sunglass cloths) or as sswilson stated a Coffee filter.
That does the trick every time.
-ST
Old September 13, 2012, 06:25 AM
stoanee's Avatar
Originally Posted by sswilson View Post
Alcohol + coffee filters does the trick for me. :)
I have the alchohol figured out, I drink a couple of shots before I work on the paste but now the filters, do I use them before or after I brew with them?
heatware
Old September 13, 2012, 06:50 AM
sswilson's Avatar
That depends, are you mixing it with rye (irish coffee) or rum (not completely sure what nationality this belongs to.... )? :)
Old September 13, 2012, 06:59 PM
Galcobar's Avatar
We're Canadian, we get to use every culture's vices.
Old September 14, 2012, 10:06 AM
Been using the Alcohol swabs for a while, no issues for the CPUs so far.
DONT use the nail polish remover it is very strong stuff (I think known as Thinner?), and if there are remnants of nail polish it will give a nice paint coat to the CPU
Ma Heat:
http://heatware.com/eval.php?id=67149
Old September 14, 2012, 10:14 AM
sswilson's Avatar
Pretty sure nail polish remover is acetone based. AFAIK anything that'll take automotive paint right down to the bare metal in seconds shouldn't be used on PC parts.
Old September 14, 2012, 12:22 PM
@ sswilson yep second that.
Loooong time ago, when PS1 was the king, I used nail polish remover it to "CLEAN" the lens needless to say had to get a new PS1 ...
O the young and the dumb days.....
Ma Heat:
  #19 (permalink)
Old September 14, 2012, 01:15 PM
Perineum's Avatar
I've used this for a decade or so....
Certified Brake Cleaner | Canadian Tire
Or 99% iso if it's a smaller job.
  #20 (permalink)
Old September 14, 2012, 01:34 PM
sswilson's Avatar
Heh... I was using it to clean travel stickers off of the windshield of a used car I'd just bought, and made the mistake of laying the nail polish remover soaked cotton ball on the hood for a second or two...... As such I can say with fair certitude that it'll strip automotive paint down to the bare metal in seconds......
Thermal Paste The Quicken CPU's and Motherboards 10 December 17, 2011 07:50 PM
GTX 580 thermal paste mikellini Video Cards 13 November 17, 2010 10:37 PM
Thermal Compound Removal Help no_pulse Guides & How-to's 36 May 7, 2010 10:45 PM
Thermal Paste miggs78 Water Cooling 4 September 10, 2009 07:17 PM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 05:43 PM
