<~----> p8z77-v pro LAN issues - Hardware Canucks
Old September 10, 2012, 06:25 AM
Default p8z77-v pro LAN issues
Hi Guys,
Been having problems with my wired LAN connection (Ethernet Controller). It works when it wants to basically. It has the latest updated driver from the intel site.
It appears to work fine when i first install the driver, though when shutting the pc down and turning it back on, my internet is disconnected and the actual device isn't shown anymore.
So i've repeatedly been installing the driver on each start up.
Any ideas what is going on here? Anything would truly help!
Thanks
Old September 10, 2012, 07:10 AM
Varroa's Avatar
Sounds like it is being turned off to save power and it cannot re-start it again. In the past I have had problems with Asus network adapters on their motherboards and the only way to fix it was to use the Asus driver from their website (even if it is out of date). Give that one a try and see.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 4x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old September 10, 2012, 12:50 PM
I have tried pretty much every driver. Same thing happens. Is there some way to disable it "turning off" for power saving?
Thanks!
Old September 10, 2012, 04:08 PM
Varroa's Avatar
Yes, in the device manager find your network adapter. From there you can go into the settings and disable the power off feature.
P8z77-V Pro Issues souster CPU's and Motherboards 3 August 30, 2012 05:08 AM
2600k, P8Z77-M PRO, 16G Corsair Ram kyle_L Price Check 0 June 8, 2012 05:24 PM
p8z77 vpro VS Sabertoothz77 shogunsilly LinusTechTips Q&A 2 May 4, 2012 01:46 PM
Power design of P8Z77-V andyhan95 CPU's and Motherboards 1 April 4, 2012 02:45 AM
New Asus P8Z77-Pro Mobo Wow ginman522 CPU's and Motherboards 2 April 1, 2012 03:40 AM
