Originally Posted by Silvgearx I don't quite understand your problem. But seem like you have problem running some programs under windows 7.
Have you tried VirtualBox? https://www.virtualbox.org/
I run windows 7, Virtualbox ubuntu 10.12 and xp. |
When I tried to install XP64 I got a BSOD, quite reliably.
Just plain, not compatible. Didn't even get as far as installing drivers. It would crash out while reading the XP64 install disc & give me the BSOD.
Then I went to install Windows 7, that's what I'm working on now.
I still have the XP64 quad core workstation, and the way it's working out, that is a more productive workstation for me than the new Hex-core one.
But I thought, if not the Socket 2011 combination of 3930K/ Asrock Extreme 6, then maybe a 2700K/2600K system would be compatible with XP64.
For me, running Max 9 (vintage 2008) is more important than having Autodesk Max 2013. The Max 9 license is paid for and it has more useful features.
But since the Max 9/ XP64 combination
works, I'm trying to find the fastest system to run it on.
