Old August 31, 2012, 11:32 AM
by todays' standards 4gb is a minimum. My recommendation to keep costs down would be a cheap 1155 CPU and a budget graphics card. Here is a review of a Pentium G620 with HD6670 vs A8 3870k. You could go up on the video card if you felt the need, but it should be fine for what it will be used for.
http://www.tomshardware.com/reviews/...6670,3140.html
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old August 31, 2012, 12:46 PM
^thanks for the recommendation
the 2GB was fine for Win7 web browsing/youtubing. but ya, I don't remember anyone playing games on that system.
i would feel kinda gross buying DDR2 ram :/
Old August 31, 2012, 06:38 PM
Here is the basis for a cheap gamer (its not going to be feature rich, but it will work no problem).
HD 6670 for $50 or HD 7750 for $80 after MIR
Cheap MOB for $50
Celeron G540 for $40
4Gb Ram for $25
Seasonic 350w power supply for $20
Thats $185/$205after MIR depending on graphics card. Add a case, hard drive, dvd burner ($15), and an OS and you are good to go.
Old September 3, 2012, 10:47 PM
i recommend 7750 if you can find one under 100$. 7770 under 120$.
Ram is relatively cheap nowadays, it shouldnt be a problem to grab 4gigs for 25$. or heck a little higher 41$ for g.skills or corsair ram.
Processor wise, Intel for future proof. Amd is right now, i don't recommend it.
Best luck.
Old September 3, 2012, 11:15 PM
supaflyx3's Avatar
The onboard GPU will be fine to play MOH at 1080P max settings.
AMD A8-3870K Unlocked Llano APU Review Comment Thread SKYMTL CPU's and Motherboards 10 February 6, 2012 09:33 AM
1080p out on laptop/netbook not for gaming. kyle_L Mobile Computing 8 August 17, 2009 01:32 PM
1080p Phobia Troubleshooting 7 July 4, 2008 11:00 PM
