Old August 30, 2012, 01:02 PM
Default Ivy Bridge Heat Issues
for someone who may not be overclocking at all, are there any issues with heat vs sandy bridge processors? Is the heat issue only with the i7s? or is it across the entire ivy bridge line up?
Rig will be used mostly for internet use, and video editing and capture.
if it matters, the planned rig will be using an H80 for cooling, in a silverstone FT02 case.
Old August 30, 2012, 01:20 PM
Soultribunal's Avatar
ALthough they are a warm Chip, if you are not OC'ing then the H80 will be more than sufficent. I highly doubt you will throttle the chip with heat.
If you do decide to OC..well YMMV on how high you get it. I do know they are warmer than the SB's.
-ST
Old August 30, 2012, 03:07 PM
Gameman Advanced Kid
Guest
Posts: n/a
you could get yourself an AMD phenom and AMD graphics card. from what i read and learned is that they make excellent rendering equipment. dont know if they really run "cool n quiet".
OR
you could go for water cooling on the processor only....i also suggest to you, as a Comptia A+ Computer technician, to keep room temps near 75-80f. that should keep heat issues to minimum.
let us know if that dosent work out for you.
Old August 30, 2012, 03:24 PM
Perineum's Avatar
As a CompTIA C- certified technician I recommend sitting naked in a dark hot room eating cheetos and watching porn.
Jus sayin
Old August 30, 2012, 03:38 PM
BigPhatPaulie's Avatar
OR
Eh not really with the AMD proc.... they just cant compete compared to intel for data throughput in those areas
FOR PONY..... that is alll
Old August 30, 2012, 04:22 PM
Fudd Rucker's Avatar
Jus sayin
Hey!!! Are you spying on me?
I couldnt think of something snarky or interesting to put here this time around.
Old August 30, 2012, 04:49 PM
The heat issue is mainly due to the Thermal Interface Material (TIM) beneath the processors heat-spreader, as opposed to flux-less solder on previous CPU's. The heat issue is hardly a heat issue at all, especially when you are not overclocking the chip all that hard. They consume less power, and perform better than Sandy Bridge by roughly 10 %. If you decide to overclock, you will want to stay below 1.32 V
Old August 30, 2012, 05:07 PM
Heat on ivy will be lower than on sandy.. When you oc the extra voltage you need is what causes it to produce more heat than sandy.
There is a cross-over point at about 1.3V IIRC but you can check this up on any ivy review that did any kind of decent OC testing.
Old August 31, 2012, 06:35 AM
good to know, thanks everyone..
Old August 31, 2012, 08:37 AM
Guest
Posts: n/a
Jus sayin
well......snap.
the only reponse i can think of is
so much for trying to help
Physicist explains Ivy Bridge heat problem IITSChiefII CPU's and Motherboards 10 April 24, 2012 06:56 PM
Wait or Ivy Bridge? Or Bite the Sandy Bridge? geokilla CPU's and Motherboards 14 April 11, 2012 10:37 AM
sandy bridge E or wait for ivy bridge for 1155 gingerbee Off Topic 4 February 1, 2012 08:07 PM
heat issues ToXic Video Cards 4 August 21, 2009 05:33 PM
Urgent - Do I have Heat Issues? Please look D4ng3r CPU's and Motherboards 8 December 17, 2008 01:14 PM
