<~----> Ivy Bridge Heat Issues - Page 2 - Hardware Canucks
Old August 31, 2012, 09:32 AM
Slik's Avatar
Originally Posted by phoenixrage View Post
for someone who may not be overclocking at all, are there any issues with heat vs sandy bridge processors? Is the heat issue only with the i7s? or is it across the entire ivy bridge line up?
Rig will be used mostly for internet use, and video editing and capture.
if it matters, the planned rig will be using an H80 for cooling, in a silverstone FT02 case.
If you haven't purchased the H 80 yet,you should take a look at the Antec series of liquid coolers. The H20 620 is much much more quiet than the H 80 and cools as good or better. I've tried the H 80 and H 100,and compared them to the h20 620 and 920 with way better temps and super quiet. www.antec.com
Thermaltake Level 10-i7 3930k @ 4.2ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 1600mhz- Two EVGA Titans SLI - Xonar Phoebus Sound Card-Dell 3008 30" Monitor-Razer Tiamat Headphones-Butt Kicker Gamer-TrackIR 5
Old September 2, 2012, 08:41 PM
486's Avatar
486 486 is offline
Just finished building new rig with i7-3770 (non-K) in smallest mATX case I coud find with no side perforations, just one fan in, one fan out. CM+ EVO, couple SSDs and stock 7970. Everything was set to stock / default values, no OC of any kind (TPU off). Under IBT load CPU for some unknown reason was going with x37 multiplier with hottest core just touching 64degreeC (I was expecting x34). Huge difference with stock Q9650 in BF3 64p, though.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old September 4, 2012, 03:03 AM
-Wolverine-'s Avatar
It's perfectly normal. CPU multiplier went to x37 because of Intel Turbo Boost. As IBT loaded all four cores it went up to x37. If you've had loaded only one core it would go up to x39.
If you disable Intel Turbo Boost CPU multiplier will not raise above x34 for Core i7 3770.
64 °C is pretty good. When I have tested Core i7 3770K temperatures went up to 60 °C under Prime95 and Intel Liquid cooling solution while Core i7 2600K under same conditions hit ~55 °C
''Of all the things I've lost I miss my mind the most''
Mark Twain
Old September 4, 2012, 07:28 AM
486's Avatar
486 486 is offline
Well, liquid cooling is very convenient, especially in smaller cases, but I still have prejudice against any liquid close to electronics. I am old school air cooling (Porshe-engineering-style). CM+ EVO - dirt cheap and effective. Cheapest LC is twice the price, tripple the worries.
I have set sync Turbo Boost at 4GHz. On IBT standard hottest core went up to 70degreeC, on IBT very high - 72. I hope is not too hot, as Tj is set at 105 and stock cooling normally gets 3770 to 75 under load from what I have read.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Old September 4, 2012, 07:54 AM
Yes, CM Hyper 212 Evo is dirt cheap but very effective cooler. ~70 °C isn't too hot, plus I don't think that IRL you'll stress that CPU as much as IBT. If you want lower temperatures you could try and find lowest stable operating voltage for CPU.
Mark Twain
Old September 4, 2012, 11:41 AM
486's Avatar
486 486 is offline
Yeah, I lowered voltage to 1.15V on Q9650 to get it to 3.6GHz under 75degreeC with CM+ non-EVO version. Then I just ran it at stock as I did not have any real need to get more performance out of it. Once BF3 came along - I just got 3770/7970.
I am curious though, I have never read any horror stories about LC rapturing, spilling water all over MB, shortening it badly. May be I am just paranoid old man.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Old September 4, 2012, 08:09 PM
Soultribunal's Avatar
The AIO are really reliable now, with good tubing, seals and everything else.
Plus IIRC if a Corsair Unit does that and takes stuff out, Corsair Replaces whatever it killed.
-ST
Old September 5, 2012, 01:21 PM
486's Avatar
486 486 is offline
Corsair "You own what you kill" policiy is cool one. Right out of Riddick Chronicles :)
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
  #19 (permalink)
Old September 5, 2012, 01:49 PM
Exactly why I wouldn't suggest another brand as I think they are the only ones who do this..
/Edit.. Ohh 999 posts.. :o
Physicist explains Ivy Bridge heat problem IITSChiefII CPU's and Motherboards 10 April 24, 2012 06:56 PM
Wait or Ivy Bridge? Or Bite the Sandy Bridge? geokilla CPU's and Motherboards 14 April 11, 2012 10:37 AM
sandy bridge E or wait for ivy bridge for 1155 gingerbee Off Topic 4 February 1, 2012 08:07 PM
heat issues ToXic Video Cards 4 August 21, 2009 05:33 PM
Urgent - Do I have Heat Issues? Please look D4ng3r CPU's and Motherboards 8 December 17, 2008 01:14 PM
