Old August 20, 2012, 01:19 AM
Default Sandy Bridge Heatsinks - quick question
My family member happens to have an extra intel stock heatsink from a 2600K he got. I was just wondering if it is bigger or otherwise different from the heatsinks for lower end intel SB CPUs, such as the i3-2100 or even the SB pentiums
Old August 20, 2012, 03:16 AM
supaflyx3's Avatar
No it's exactly the same.
Old August 20, 2012, 09:31 AM
techman95's Avatar
same exact cooler all around now for intel the only difference is the fan just spins alot faster for the i7's
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Old August 20, 2012, 02:59 PM
okay thanks. all i needed to know. was kinda hoping that the 2600K heatsink would be a 'free upgrade'
Old August 20, 2012, 04:25 PM
Brian@NCIX's Avatar
NCIX System Builder
The 2100's have a non-copper base, but other then that, the heatsink itself is the same. You may be able to achieve a few temp difference from it, as well as the faster fan.
Old August 20, 2012, 05:54 PM
^^^From what I have seen they all look the same, but as mentioned above the higher end cpu's have a copper core in the heatsink, whereas the low end ones are all aluminum.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Sandy bridge and Z77 BrutalGreen Overclocking, Tweaking and Benchmarking 0 June 3, 2012 09:48 AM
Wait or Ivy Bridge? Or Bite the Sandy Bridge? geokilla CPU's and Motherboards 14 April 11, 2012 10:37 AM
sandy bridge E or wait for ivy bridge for 1155 gingerbee Off Topic 4 February 1, 2012 08:07 PM
[WTB] WTB: sandy bridge cpu and SSD dpk33 Buy/Sell & Trade 7 January 15, 2012 08:15 PM
First build, Sandy Bridge Atmax New Builds 6 January 26, 2011 02:46 PM
