Old August 15, 2012, 05:35 PM
Default Ivy Bridge recommendation - Size limited
Can anyone recommend a IB board with 305 x 210mm as max limit? My friend also need it to have Intel onboard RAID so he can migrate the current RAID5. He prefers Gigabyte but open to suggestions (I know some of you don't like Giga). I suspect he may try overclock it a bit.
Old August 15, 2012, 06:22 PM
ZZLEE's Avatar
ASUS P8Z77-I Deluxe mITX LGA1155 Z77 DDR3 1PCI-E16 SATA3 DVI HDMI DisplayPort USB3.0 Motherboard - ASUS - P8Z77-I Deluxe
1155 ( not so good fore raid. )
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old August 15, 2012, 06:27 PM
Oh I pointed out that board to my friend as well. To be honest if he got a hard size limit like that he should of gone mATX, which I also suggested.
Old August 15, 2012, 06:53 PM
ZZLEE's Avatar
Bitfenix Prodigy mITX Mini-ITX Tower Case Midnight Black 1X5.25EXT 5X3.5INT No PS Top USB3.0 Audio - BitFenix - BFC-PRO-300-KKXSK-RP
only reason to go MITX ( personal Opinion ) But in this case a good one. :)
Wait or Ivy Bridge? Or Bite the Sandy Bridge? geokilla CPU's and Motherboards 14 April 11, 2012 10:37 AM
AMD 6990s Limited? musicman Video Cards 4 February 2, 2012 09:41 PM
sandy bridge E or wait for ivy bridge for 1155 gingerbee Off Topic 4 February 1, 2012 09:07 PM
Sandy Bridge-E limited BCLK? dma0991 Reviews & Articles from the Web 6 August 27, 2011 09:53 PM
Even cooler GTX 295... to bad its limited Realityshift Press Releases & Tech News 11 June 23, 2009 10:56 PM
