Old August 14, 2012, 09:04 AM
Default Overclocking and Gateway gaming desktop
My current system is a Gateway FX 6831, which uses a Gateway H57M01 (which has an Intel H57 chipset), an Intel i7-860 2.8GHz processor and 16 GB of DDR3-1333 RAM (9-9-9-27 & 1.5V). The CPU multiplier is set at 21 * 133, resulting in an average 1.1V Core Voltage.
My question is how far might I be able to overclock this system? Are branded computers usually fixed to prevent overclocking, or could I get some more power out of this thing?
Old August 14, 2012, 09:09 AM
Overclocking.ca's Avatar
Most OEM systems have a locked BIOS which does not allow for overclocking. I did a Google search and this is the same for your system. They lock the multiplier at 22x.
Old August 14, 2012, 09:10 AM
SugarJ's Avatar
The H57 chipset does not overclock. You need a P67 chipset board to overclock. And yes, almost all OEM systems are locked to prevent overclocking, either by the chipset or by the BIOS.
Old August 14, 2012, 09:26 AM
Skyllz's Avatar
Agreed to what the other on top have said.
Only way to "get out of this" would be to replace the mobo with something off the shelf like Asus, Gigabyte and others, get a good CPU cooler, then reinstall windows and go to town :)
Is smoke supposed to come out of there?
Old August 14, 2012, 09:54 AM
Fudd Rucker's Avatar
This is socket 1156, the chipset or multi lock wouldnt make a diff since since these chips didnt have the base clock speed tied to everything like the 1155 series. My last experiance with an i7 860 i clocked it @ 200mhz x 20 for a clockspeed of 4ghz. And that was achieved on a crummy h55 mobo. Although Im doubting your board will do the same, i dont see why 200x 18 netting 3.6ghz isnt achievable providing the proper features arent locked. ie : qpi, and voltages. Make sure the VRM would be up to snuff for clocking.
I couldnt think of something snarky or interesting to put here this time around.
Tags
gateway , h57 , i5-860 , overclocking
Gaming Desktop - Part out? RockCrayfish Price Check 7 March 27, 2012 07:51 AM
Gaming Desktop advice akazzz New Builds 9 October 19, 2011 12:28 PM
[FS] Gateway FX Gaming Laptop Table21 Buy/Sell & Trade 3 August 25, 2009 05:43 PM
[FS] sell gaming desktop hohohee Buy/Sell & Trade 7 April 24, 2009 02:55 AM
