Old August 8, 2012, 03:08 PM
Slik's Avatar
Originally Posted by biggyk View Post
Yeah, I forgot I had some Artic silver 5 laying around so I tried it but no difference so I then posted on here.
Computer is running fine so if you all say 60 peak is good then im good Usually its more like 55-58 anyway.
There you go bro. Don't change anything. It took me a LOOOONG time to really get it when they say...If it ain't broke,don't fix it.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old August 8, 2012, 08:36 PM
That is pretty good compared to mine. I was using the coolit eco on the 955 on stock clocks and it was going over 62 while playing games. In order to get the temperatures lower I had to undervolt to cpu.
Old August 9, 2012, 04:32 AM
Good temps for your setup. I'd leave it. Even if you made it an intake with another fan and used the best TIM you would just be nickle and diming your temperatures.
Very warm TX750 at around half load 0o0 Power Supplies 9 December 24, 2009 08:18 PM
My new CPU seems to get warm mrlie3 Troubleshooting 7 August 4, 2007 07:00 AM
