Old August 7, 2012, 11:34 AM
Question buying cpu tomorow wich one?
hi i wana buy i5 3570k or i7 3770k . i will most just gaiming watch movies music and internet.
Old August 7, 2012, 11:42 AM
SHiFT.'s Avatar
For the tasks you are preforming you should be fine with the i5 3570K
Old August 7, 2012, 11:52 AM
Soullessone21's Avatar
I like my 3570k more then my 3770 the heat is still high its just not insanely high
Current Build:http://www.hardwarecanucks.com/forum...cube-gods.html
Always up for a Beer in Calgary or Area
“Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.”
Old August 7, 2012, 11:55 AM
do i get same performance in game with i5 3570k as i will get with i7 3770k no diferents in game?
Old August 7, 2012, 12:16 PM
No difference worth the price increase. There are VERY few games that will properly take advantage of hyperthreading.
We are shaped by fate, just as we shape it.
Old August 7, 2012, 12:27 PM
I have not noticed any difference at all, the 3570k is a awesome chip I absolutely love it other then the IVY heat issue that is extreme to say the least, well it reads out as hot but does not put off tons of heat. I will be posting a build in the coming weeks that I use that CPU but it was the special edition with intel water cooling and I think its great. dont waste your money on the 3770 its not worth it :)
Old August 7, 2012, 12:36 PM
ok thanks i saw the i5 3570k in newegg for 229$ and in micro center just for 189$ nice:)
Old August 7, 2012, 05:29 PM
Ravenor's Avatar
3570K will do you perfectly
I Feel Amazing Expendable! - Misc. Imperial Guard
Old August 7, 2012, 08:35 PM
Battlefield 3 uses 8 threads and thus will benefit from the 3770k.
More games will come out that will be able to use more threads. It certainly can't hurt to have twice as many threads.
wich hdd are the best? netgears Storage 19 August 17, 2012 06:39 PM
wich 16gb ram should i buy karolis RAM 11 July 13, 2012 10:20 AM
Buying PS3 Nevakonaza Gaming 36 July 29, 2010 03:48 AM
Wich 22"? mitchel Display Units 1 August 16, 2007 06:34 PM
