-   -   Maximus V Formula Power (http://www.hardwarecanucks.com/forum/cpus-motherboards/55821-maximus-v-formula-power.html)
Nevermoar July 31, 2012 07:55 PM
So I bought a Maximus V Formula. It should be here tomorrow. I seem to have misplaced the 4 pin power connector on my PSU so I only have the 8 pin. Is this completely necessary? Do I need to plug in both the 8 pin and the 4 pin? I'm keeping the same 2600k I have in my Maximus IV Extreme, same RAM, same everything. I plan to get a new PSU at the end of August. Can I get away with this until then? Is it safe?
Nevermoar July 31, 2012 09:02 PM
Found my modular cable...
http://dannybrown.me/wp-content/uplo...ccess_baby.jpg
Masteroderus August 1, 2012 04:03 AM
I found I could get higher stable overclocks with more power plugs plugged into the mobo.
However, I think it should be ok to run your system with a single 4 pin, but you may have to use stock clocks.
UNTAMED August 1, 2012 03:57 PM
"so I only have the 8 pin" all that is required
8 + 4 is only required for sub zero oc it seems
