Old April 14, 2008, 11:25 AM
Talking Finally a Computer Canuck site !!!
Hi all.
Been awhile since i put a puter together, so i have a few question.
My setup is as follows so far
CS - CM 690
PS - SafePower 550 watts (for now till i get new one)
Mobo - P5K-E/Wifi-AP
Now here are the question?
1 - do i need to use the EATX12V on mobo
2 - if yes to above question then where can i get an extension for the
4 pin cable because the one that comes with psu is not long enought to reach the
pins on the mobo.
CM 690 case psu is at bottom of case and EATX12V on mobo is found at the top.
Thanks...
Old April 14, 2008, 11:27 AM
CMetaphor's Avatar
Quadfather
Hi and welcome to the forum!
1- Yup.
2- http://www.ncix.com/products/index.p...ECH%20COMPUTER
Hope you enjoy it here!
Old April 14, 2008, 11:31 AM
Sorry also forgot to say the cpu is a Q6600 - Core 2 Quad
Thanks
Old April 14, 2008, 11:36 AM
CMetaphor's Avatar
Quadfather
Then you'll probably need the 8-pin version of the above... like this:
8 EPS 8 PIN POWER ........... EXTENSION CABLE - DirectCanada
