Old July 28, 2012, 05:48 PM
Default i7 3770k overclocking problem
hi, when i overclocked my i7 3770k and set the voltage to 1.45 the system worked well but the games like bf 3 and spec ops the line stoppeds working error , i dont know if the problem came from the overclocking or not .
Old July 28, 2012, 06:39 PM
BigPhatPaulie's Avatar
1.45??? thats way to high for a 3770k. The MAX that chip should run at is 1.3 or lower on air cooling and even water
FOR PONY..... that is alll
Old July 28, 2012, 06:55 PM
you mean i should run it 4.9 ghz at 1.3
Old July 28, 2012, 07:10 PM
Intel i7 3770K at 4.9 GHz at 1.45V - Cinebench - YouTube
Old July 28, 2012, 07:32 PM
gingerbee's Avatar
dude even on water thats just pushing to hard on that chip for me it may not be for you but the performance you get outta of it is almost no increase for all that heat drop it down to 4.5,4.6 and a nice low voltage my 2 cents
IE this is why i got outta the 3770k-3750k and socket 1155 for overclocking heat was just killer when now i am running a 3820 at 5.0@1.44 and my temps are all under 80c like i said it wont kill your chip tonite but given a few months or years and that thing is cooked
Old July 28, 2012, 07:59 PM
the temp dont bother me , i have a problem and no one answer it , i got yhis chip stable at 1.36v when overclocked it to 4.8 but the only thing that bother me is bf 3 and spec ops the line told me tha game has been stopped working when overclocked this chip
Old July 28, 2012, 08:15 PM
gingerbee's Avatar
then it not stable it's that simple sorry man you would have to list all your specs and the voltages your using to get your overclock.
edit if you havent taken the time to work out if it's the overclock well that would be the first place to start remove your oc and run it at stock and see if you have the same problems if so re-install the games and start fresh. first things first
Old July 28, 2012, 08:36 PM
my spec : asus sabertooth z77 the latest bios
G.SKILL 2X4 8GB 1866 SNIPER 1.5V . NOCUTA NH - D 14 COOLER
THE GAMES WORKS well when overclocking cpu to 4.8 1.4v and when the cpu is at stock clock . but i want to go for 5 ghz but i cant do this
Old July 28, 2012, 08:38 PM
edit
ok you asnwered my question before i posted.
maybe your cpu can't do 5ghz or you need different settings to achieve stabilty, or you just need more cold.
wanting something doens't make it so
Old July 28, 2012, 08:50 PM
i can achieve 4.9 ghz but with high volt
FYI: 3770K overclocking on Z68-UD4 not work. dandelioneater Overclocking, Tweaking and Benchmarking 8 December 19, 2012 08:42 AM
i7 3770 k overclocking problem yehia7000 CPU's and Motherboards 3 July 24, 2012 08:16 PM
Test for BIOSTAR TZ77XE4 loading with Core i7-3770K overclocking 4.8G windwithme CPU's and Motherboards 3 June 1, 2012 09:58 PM
Strange overclocking problem (update 07/2011) Varroa Troubleshooting 12 July 22, 2011 11:07 AM
Problem overclocking my E8400 lanken123 Overclocking, Tweaking and Benchmarking 10 February 10, 2010 02:18 PM
