  #21 (permalink)
Old July 30, 2012, 08:47 AM
BigPhatPaulie's Avatar
Yea what he said, still not quite sure how your getting those temps even with AC and the noctua tower..... but regardless of that 1.5 is just to much voltage for everyday use man,4.7 at 1.35 is MUCH better and you wont see a difference in performance, but your chip will last longer
FOR PONY..... that is alll
  #22 (permalink)
Old July 30, 2012, 02:34 PM
i overclocked it now to 4.9 with 1.45v and i thought it is not high voltage because there is reviews that overclocked this chip with higher voltage check this :Ivy Bridge Debuts: Intel Core i7-3770K Review > Overclocking Performance - TechSpot Reviews
Intel i7 3770K at 4.9 GHz at 1.45V - Cinebench - YouTube
i dont use this overclock all the day i used it only while playing games like skyrim , prototype 2 , bf 3 multiplayer . i know that you are right about high temp about some programs like cinbench 11.5 and aida 64 the temp was about 82 celisus and this is because the cpu core usage is 100% and all the processors will have high temp but not like ivy bridge . thank you guys for your help.
  #23 (permalink)
Old July 30, 2012, 06:40 PM
OHHHH that makes so much more sense now okay
FYI: 3770K overclocking on Z68-UD4 not work. dandelioneater Overclocking, Tweaking and Benchmarking 8 December 19, 2012 07:42 AM
i7 3770 k overclocking problem yehia7000 CPU's and Motherboards 3 July 24, 2012 08:16 PM
Test for BIOSTAR TZ77XE4 loading with Core i7-3770K overclocking 4.8G windwithme CPU's and Motherboards 3 June 1, 2012 09:58 PM
Strange overclocking problem (update 07/2011) Varroa Troubleshooting 12 July 22, 2011 11:07 AM
Problem overclocking my E8400 lanken123 Overclocking, Tweaking and Benchmarking 10 February 10, 2010 01:18 PM
