Old July 28, 2012, 10:10 PM
is 70 digree temp high for ivy bridge
Old July 28, 2012, 10:19 PM
gingerbee's Avatar
nope for it (ivy bridge) i go with anything under 80c is fine.
Anything over ( even though it's thermal trip doesn't kick in till well over 90 ) is just slowly helping kill the chip
It's kinda like your car sitting still running at 3500 rpm not bad for it but not a smart thing to do for hrs/days/months/years as if it would ever get that far lol i think you get my point but 70 is wicked for a decent temp if your oc is nice what are you getting for ghz at those temps
edit to add from what i have seen and heard 5ghz is pretty rare fro ivy bridge without extreme cooling may just sell your ivy and get yourself a 2600k whick most will do with some easier then others most i found all sandy bridge hit 5ghz easier then ivy
Old July 28, 2012, 11:13 PM
i can hit 4.9 ghz with 1.5 volt but the temp doesnt go above 75 celsius
Old July 29, 2012, 08:05 AM
Your_friendly_gamer's Avatar
wow 1.5v thats wayyy toooooooooooooooooooooooooooooooooooooooooooooooo high. Instead manually overclocking, use the asus overclocking utility. It's really good.
Old July 29, 2012, 10:11 AM
how i get 4.9 with 1.3 - 1.4 v
Old July 29, 2012, 10:13 AM
overclocking utility is so bad overclocking
Old July 29, 2012, 11:13 AM
BigPhatPaulie's Avatar
How are you getting those temps at that voltage? what cooling? because air cooling cannot (at least acording to the numerous reviews) keep that chip cool at 4.7 let alone what your running. Also 4.9 shouldnt be possible at those voltages.
Edit: also the in the uploaders comments for the youtube link you posted the guy said that it wasnt stable at that voltage and clock speed
FOR PONY..... that is alll
Old July 29, 2012, 11:34 PM
i have air conditioning in my room so the temp in the room is about 17 digree now and i have it overclocked to 4.9ghz and the max temp in cores is 62 celisius in bf 3 playing the game 2 hours
  #19 (permalink)
Old July 29, 2012, 11:48 PM
I have this processor stable in all games like ( bf 3 64 players multiplayer , spec ops the line , ghost recon future soldier ) ,first i overclocked it to 4.7 with 1.35 vcore using llc option to extreame and when push it to 4.9 at the same volt there is no is no stable , so i have to increase volt to 1.45 to be stable i ran bd 3 two hours the max temp of cores is 62 celisius and i have air conditioning in my room so the temp in my room is 17 , the only thing bad in ivy bridge is that the temp is not stable even in idle , i have
nocuta nh-d14 and it is better than any liquid cooling except corsair h100 , i overclocked it to 5 ghz with 1.5 v but the temp goes high so i redused the clock again to 4.9
  #20 (permalink)
Old July 30, 2012, 05:08 AM
Fudd Rucker's Avatar
sounds like your chip just wont do 5ghz stable without an extreme solution.1.5v is just asking to kill your chip fyi.
I couldnt think of something snarky or interesting to put here this time around.
FYI: 3770K overclocking on Z68-UD4 not work. dandelioneater Overclocking, Tweaking and Benchmarking 8 December 19, 2012 08:42 AM
i7 3770 k overclocking problem yehia7000 CPU's and Motherboards 3 July 24, 2012 08:16 PM
Test for BIOSTAR TZ77XE4 loading with Core i7-3770K overclocking 4.8G windwithme CPU's and Motherboards 3 June 1, 2012 09:58 PM
Strange overclocking problem (update 07/2011) Varroa Troubleshooting 12 July 22, 2011 11:07 AM
Problem overclocking my E8400 lanken123 Overclocking, Tweaking and Benchmarking 10 February 10, 2010 02:18 PM
