-   -   Project Mobile gaming (http://www.hardwarecanucks.com/forum/cpus-motherboards/55746-project-mobile-gaming.html)
Soullessone21 July 28, 2012 10:15 AM
Okay big issue I found in the new sponsor build HEAT holy shit the 3570k gets hot. I only had a hour to play with it last night but it idled at 50-60 and just web surfing hit the 70s going to have to figure something out.
Will include a build log in the right area Soon. Need to know what normal temps are with that CPU?
lowfat July 28, 2012 10:34 AM
The high temperatures are mostly due to the poor thermal interface material used between the CPU die and the IHS. It isn't actually throwing out that much heat. They run very warm because of it unfortunately.
Soullessone21 July 28, 2012 12:02 PM
I head about that didnt think it was this bad :( this is a real disapointment this is for a sponsored giveaway...
We will still mod the case to fit the intel water cooler in and see if we can get things a little better.
Thanks
Soul
zsamz_ July 28, 2012 12:33 PM
Thanks
Soul
wont do much good ihs needs to be poped open
big temp differences then
NSdeadly1 July 28, 2012 02:14 PM
This is exactly why I'm sticking with my 2500k for at least another generation. I've read similar posts on a lot of other forums, though the heat doesn't seem to bother the cpu's too much.
