Old July 26, 2012, 09:08 AM
Default sabertooth z77 . cpu fan error!!!
i have sabertooth z 77 with nocuta NH-D14 and when it starts it says cpu fan error press f1 .
Old July 26, 2012, 12:45 PM
Did you plug the fan into the correct fan header? When it say CPU Fan error it usually mean the fan is not spinning. However, given your other post about PCI-E temp warning, I'm starting to suspect you may have a defective motherboard.
Old July 26, 2012, 02:38 PM
Ravenor's Avatar
You could also try turning off the CPU fan warning in the bios and see if that fixes it.
I Feel Amazing Expendable! - Misc. Imperial Guard
Old July 26, 2012, 05:47 PM
yes i make it ignore from the bios and it fixes it and the fan works well buuuuuuuuuuut the only problem is thermal radar it gives me wrong temp because i downloaded open hardware and the temp is away different especially with cpu as thermal radrar gives 45 digree cpu temp but the open hardware gives me 62 digree while playing bf3 so the PCI-E 1 used by graphic card temp might be false . i am confused know and i dont find any one here to help me in this problem
Old July 26, 2012, 06:00 PM
BigPhatPaulie's Avatar
have you googled the issue at all? have you tried updating the bios and the asus software? have you talked to asus themselves? People are trying to help you as best as they can but its not a lot of info to go off of sometimes man just sayin
FOR PONY..... that is alll
Old July 26, 2012, 06:24 PM
Ravenor's Avatar
True using CPU Temp to read your temps. I find it is a very reliable program to read your temps. Just to rule out the other program not working correctly with the mobo or reading the temps from the bios accurately.
Ram Compatible With Sabertooth Z77? PcWizTech New Builds 3 July 19, 2012 10:28 PM
[FS] FS: Sabertooth P67 Eldonko Buy/Sell & Trade 7 June 13, 2011 06:57 PM
Error 101 (net::ERR_CONNECTION_RESET): Unknown error. chiknhawk O/S's, Drivers & General Software 1 April 30, 2011 05:08 AM
sabertooth x58 not boot CTA Troubleshooting 43 March 4, 2011 12:48 PM
Update error code 8000ffff - unknown error hedgehog88 O/S's, Drivers & General Software 2 August 22, 2010 08:23 PM
