-   CPU's and Motherboards (https://www.hardwarecanucks.com/forum/cpus-motherboards/)
-   -   sabertooth z 77 pci-e high temp (https://www.hardwarecanucks.com/forum/cpus-motherboards/55669-sabertooth-z-77-pci-e-high-temp.html)
yehia7000 July 25, 2012 06:21 PM
why i test prime 95 ? .prime 95 used for cpu stability and ungine heaven is tesslation test . this high temp coming when playing bf3 and heavy games but on idle pci-e 1 is 45 and pci-e 2 is 41
sf101 July 25, 2012 08:52 PM
thats really a odd error
hows air flow in the case? perhaps its reguarding cooling on your chipset
also are you running ai suite it can have problems also conflicts with things like precision and afterburner.
also its a good idea to use a program like afterburner if your not and make a fan profile i've seen alot of cards run hot without this.
yehia7000 July 26, 2012 02:49 AM
i run an air conditioning so the temp in the room is about 20
