Old July 24, 2012, 04:09 AM
Default is intel hd 4000 work with discrete gpu
help please!! when i played games i dont know if intel hd 4000 in my i7 3770k work with discrete gpu gtx 590 and i dont install any driver of intel hd 4000 because it says error you computer doesnt meet the lowest requirements for the software
Old July 24, 2012, 07:04 PM
they don't work together. You either have to use the hd 4000 or the gtx 590.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old July 25, 2012, 06:57 AM
I generally thought that if you add a graphics card the CPU graphics is turned off automatically. But what do I know? Somebody with superior knowledge should chime in . . . .
Old July 25, 2012, 07:19 AM
Pabz0r545's Avatar
If your motherboard has LucidVirtu you can use both together.
Old July 25, 2012, 09:41 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Let's clear the issue.
Lucid's drivers don't currently work with the GTX 590 anyways so there's no chance of that....
If the monitor is plugged into the graphics card, it will be using the graphics card provided the NVIDIA drivers have been installed.
Discrete Audio kicks ass! great_big_abyss Audio 0 November 23, 2011 06:52 AM
I get 400 point instead of 4000 on SMP2 Lanboy HardwareCanucks F@H Team 8 June 12, 2011 09:47 AM
Is TRIM work on Intel gen 2 set on IDE Lanboy Storage 7 June 9, 2011 09:21 AM
integrated and/or discrete video? Epimetheus Video Cards 1 April 11, 2011 12:51 PM
WIP GOMERS 4000 DOLLAR BOX gomer Case Mods, Worklog & Gallery 8 September 27, 2010 06:33 PM
