Old July 24, 2012, 03:19 AM
Default cpu fan error ?? help
help,(cpu fan error ),,that is the message when i enter the bios in my sapertooth z77 i have nocuta nh d - 14
Old August 8, 2012, 08:54 PM
nna2's Avatar
Trial Member
go to your hardware monitor menu (or the one that lists temps/fan speeds) and where it says CPU fan, hit enter and disable it
your fan is spinning slower than the lower limit in the BIOS, so it thinks there's somthing wrong
http://valid.canardpc.com/show_oc.php?id=2456771 Pics of my system https://www.dropbox.com/sh/t6uqfanr [...] W/My%20Rig
Old August 8, 2012, 11:54 PM
Hmm another Sabertooth having CPU fan error.
Old August 14, 2012, 06:21 AM
elmorejohn46's Avatar
The fans on them nocuta nh d - 14 do spin pretty low, as long as your tempertures are fine then there is nothing to worry about ,but as said to get rid of the message you will need to go in your Bios and disable the fan monitoring.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Fan Error shabba100 Water Cooling 3 November 27, 2011 08:59 PM
Error 101 (net::ERR_CONNECTION_RESET): Unknown error. chiknhawk O/S's, Drivers & General Software 1 April 30, 2011 05:08 AM
Error 51 muse108dc Gaming 10 August 26, 2010 02:10 PM
Update error code 8000ffff - unknown error hedgehog88 O/S's, Drivers & General Software 2 August 22, 2010 08:23 PM
Is 1 ram error too many? shaw Troubleshooting 7 April 20, 2010 11:47 AM
