Old March 12, 2007, 08:17 AM
Babrbarossa's Avatar
Default C2D temperature woes
I've been wondering what's behind my idle-temperature fluctuations and sswilson suggested that it might be the psu (couldn't find the thread where we discussed it so I started a new one). I tested the 5 and 12 volt rails today using a molex connector and found that my 5V stayed between 5.02 and 5.03 during boot, idle, and load, while the 12V stayed between 12.38 and 12.40 during boot, idle and load so I guess there's nothing out of the ordinary there- One strange thing I did notice was that there was 1.17V running through the 12V when the computer was shut off- does this have something to do with the cmos battery?
psst, wanna see my binder?
Old March 12, 2007, 08:28 AM
sswilson's Avatar
You'll need to check the specs and see what 12v rails everything is on.
Your molex connectors are probably not on the same rail as your cpu so it's possible that the cpu rail is low while the other ones are not being loaded.
Old March 12, 2007, 08:44 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Bingo. On the GameXstream, if you are measuring the voltages off of a Molex connector you are taking readings from the +12V3 rail which powers your accessories and not your CPU.
If your +12V1 (CPU) rail was dropping that much below spec, you would have alot more issues other than a few idle temperature drops.
Old March 12, 2007, 08:46 AM
I checked three different molex connectors and they were all the same- just now I checked the atx main connector and it was a little lower but still ok - 12.37 on boot and idle, and 12.35 under load.
Today's idle temps are:
Program core 0 core 1
TAT 47 45
Speedfan 52 na
CoreTemp 46 45
friday they were in the 30's on TAT
As far as other symptoms- like I was saying in the other thread to wilson (wherever it went)- I had some freeze-ups last week with loud beeping- my system had been stable for a month unchanged before that.
Also- I find that one of the molex connectors seems to underpower things- fans spin too slow, gas tube light only lights half-way when it was pulgged into that molex (last I tried anyway)- that connector tested fine for voltage. Anyway- I'm more concerned with why the temos are changing daily- this may not have anything to do with the power supply, but it's as wilson said- it's a good thing to check, I guess.
Old March 12, 2007, 08:51 AM
SKYMTL's Avatar
Personally, I think it is just a malfunctioning temperature probe.
Old March 12, 2007, 09:05 AM
That was the first thing that crossed my mind. I have the newest version of speedfan v4.32 and it measures both Tjunction and TCase- typically Tjunction is supposed to be about 15 degrees hotter than TCase and mine is measuring 7 or 8 degrees lower.
I'm a little concerned because if this is so, then I have been running my cpu at about 80 degrees Tjunction under load. It would mean that TAT, which I have been relying on has been reading temps that were 23 degrees too low! I realize it can't be that bad, or it wouldn't be stable, but It's pretty annoying not knowing what temperture to trust.
Old March 12, 2007, 09:51 AM
I've been monitoring with speedfan and core0 is showing strange temperature spikes at fairly regular intervals that don't seem to be related to any processes. The top green line is Tcase which should be lower than Tjunction apparently.
Old March 12, 2007, 01:33 PM
Well- both the Tjunction and Tcase dropped ten full degrees for no apparent reason- it's consistent on all the temo monitors- bizarre!
Old March 12, 2007, 01:50 PM
Speedfan is the WORST program to monitor cpu temperatures or any temperature for that fact.
Old March 12, 2007, 01:58 PM
I usually rely on TAT or Coretemp- - the reason I'm using Speeedfan today is that the new version tracks both type of temp sensor, and I wanted a 'second opinion'
I'm positive that speedfan 'sucking' isn't the reason my temps are fluctuating so wildly.
My Overclocking Woes... Cptn Vortex Overclocking, Tweaking and Benchmarking 20 February 8, 2008 07:40 PM
Max temperature Vinnie Overclocking, Tweaking and Benchmarking 4 November 28, 2007 08:08 PM
Way too many temperature readings! Mibs Water Cooling 2 August 4, 2007 12:00 PM
Dual Core Gaming Woes mattydies Troubleshooting 10 July 5, 2007 04:16 AM
Fan speeds, temperature... omgwtf CPU's and Motherboards 21 May 25, 2007 04:58 PM
