<~----> C2D temperature woes - Page 2 - Hardware Canucks
Old March 13, 2007, 09:29 PM
Babrbarossa's Avatar
I ran into some instability today- wouldn't play COH without restarting, so I tried it "linked and synched" at 400fsb 1:1 to see if it was more stable, but it actually seemed worse- orthos stopped almost instantly. So I ended up unlinking and dropping the cpu back to 3.0GHz and it's ok- just leaves me wondering whatthe hell is going on
psst, wanna see my binder?
Old March 13, 2007, 10:39 PM
Is your ram voltage high enough to support the speeds you want?
Don't forget some conroes can only be pushed so far before they gag.
Old March 14, 2007, 05:13 AM
my ram is at 2.1 which is normal for it, and my system has been stable for months at 3.4GHz, yesterday (haven't put it back up yet) it was unstable at even 3.2- you think the silicon has migrated on the chip or something? according to TAT, I have never pushed the temperatures -
Old March 14, 2007, 08:12 AM
My A.C.Freezer Pro 7 cpu fan is only turning at just over 1000 rpm and I can't figure out how to get it to go faster- I've turned them all up to 100% in the bios and I've done it in speedfan too- that cooler will turn up to 2500 rpm so I know it's not a limitation of the cooler
Old March 14, 2007, 09:25 AM
I think with the fan you may have to turn control of of it off in the bios :( or get a fan controller for it. My CPU is passively cooled so I don't worry about that :)
In regards to your ram if you've never overheated the ram or pushed it to far it should be fine.
In regards to the CPU i have heard of rare cases of which that once you overclock your CPU to a point, trying to downclock it may not work again.
Old March 14, 2007, 09:31 AM
Thanks! I appreciate the input- My cpu cooler is supposed to be variable speed, but if you think turning control off would help, I'll sure try it- do you know how it's done? Should I try plugging the connector in somewhere else?
I'm starting to thik that the problem initiated from having bad Tjunction temperature sensors that were reading much too low, and since the fan speeds are based on those temps, the fans weren't engaging when they should so that my cpu has been slightly toasted- I'd still like to figure out how to get those fan speeds up to prevent further toasting.
Old March 14, 2007, 10:51 AM
Theres an option in your bios that allows automatic adjustment of fan speed or "throttling". I'd try turning that off and see what happens.
Old March 14, 2007, 11:17 AM
Mine seems to only allow "Auto" or "Manual" manual allows you to adjust the %- I now have it on manual and set to 100%
Maybe I'll try switching it back to "Auto"
  #19 (permalink)
Old March 14, 2007, 11:44 AM
You running the Evga 680i?
  #20 (permalink)
Old March 14, 2007, 11:46 AM
yup- i have the new revision on order, though- interested to see if that makes a difference
My Overclocking Woes... Cptn Vortex Overclocking, Tweaking and Benchmarking 20 February 8, 2008 07:40 PM
Max temperature Vinnie Overclocking, Tweaking and Benchmarking 4 November 28, 2007 08:08 PM
Way too many temperature readings! Mibs Water Cooling 2 August 4, 2007 12:00 PM
Dual Core Gaming Woes mattydies Troubleshooting 10 July 5, 2007 04:16 AM
Fan speeds, temperature... omgwtf CPU's and Motherboards 21 May 25, 2007 04:58 PM
