Old July 5, 2012, 11:04 AM
Default Need help choosing a mobo for an i5
Hello canucks,
I'm buying this: i5-3570k and I need a motherboard to go with it. I can't say my CPU/Mobo knowledge is up to date, so I'm hoping the community can help me find a mobo that will do the job for a good price.
Here are some facts that may help determine an ideal mobo for me:
  • I use this computer strictly for gaming.
  • I don't care for overclocking potential (for now).
  • I have a 750W Corsair PSU.
  • I need it to support this RAM.
  • My budget is $180.00 and not a dime over.
  • Must be available from newegg.com/.ca (since I will be ordering the rest of the rig from there).
Thanks for your assistance!
- Kara
Old July 5, 2012, 04:59 PM
NSdeadly1's Avatar
Newegg.ca - ASUS P8Z77-V LE LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Newegg.ca - ASUS P8Z77-V LE PLUS LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Newegg.ca - GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Newegg.ca - MSI Z77A-GD65 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Newegg.ca - ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
I'm not sure if you have a brand preference or what form factor you are looking for (ATX/MATX) but these are just a few very good boards around your budget. Out of these i would recommend the MSI. All of them should work with that ram as it is pretty standard spec. hope this helps :)
Old July 5, 2012, 06:12 PM
id get the P8Z77-LK
Tags
advice , i5 cpu , mobo , motherboard
Need help choosing what to do! shelfelf New Builds 7 May 15, 2012 06:57 AM
Need help choosing from some I7 Mobo's quikgp CPU's and Motherboards 3 May 28, 2009 04:51 PM
Need Help Choosing x58 Mobo aramadia New Builds 16 March 27, 2009 06:34 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
Need help choosing! Kassela CPU's and Motherboards 5 December 20, 2007 02:56 PM
