Originally Posted by Galcobar Your other option is to get a Z77 motherboard which is designed with extra PCI-E lanes, usually via a PLX PEX8747 chip which doubles the number of lanes supported by the processor. The ASUS Z77 Maximus V Extreme, for example, supports configurations of x16/NC/x16/NC, x16/NC/x8/x8, or x8/x8/x8/x8. Similar models include EVGA's FTW, ASUS' WS models, and Gigabyte's G1. Sniper 3. |
I could be wrong but for sli on the MVE it will run @ x8 + x8 as it will bypass the plx chip for
2 cards per asus.
because of that , I went with the MVF for sli.[ less chips cut into traces] I'll buy new cards/block's before going tri , I like wc gpu's and will buy 2 block's and cards but not 3.
-on the z77 it has x16 pci-e 3.0 ,so x8 + x8 sli is the max. data with or without a plx chip.
just saying
equal to the x79 running pci-e 2.0 x16 + x16 with out the hack.
Geforce 600 Series Gen3 Support On X79 Platform.
