Old June 29, 2012, 06:03 AM
Default can somone please help me with a cpu :) cheers
i currently have a gigabyte 970a-d3 boared and im extremly empressed with so far but i want to upgrade my processoer i also have 8 gigs of 1600mhz vengence ram but only running at 1333 due to me having a 3.2ghz phennon, these are the cpus i have decided.
AMD FX 4170 4-Core Processor ( if i get this i will buy a Cooler Master Hyper 212 EVO) $139
AMD FX 6200 6-Core Processor $175 with the standard fan
AMD FX-8120 8-Core Processor $185 with the standard fan
what will give me the best performance ?
Old June 29, 2012, 06:38 AM
great_big_abyss's Avatar
Out of those three...the 8120.
Old June 29, 2012, 07:49 AM
None of the above. First the RAM speed will probably give you marginal performance gain. Second, Piledriver is only a few months away so why invest in Bulldozer now which only run a bit faster than the 1100T. Unless you're running a X2 and can't / won't wait for Piledriver then FX8120 is reasonably priced. You may even find one around $160, depending on your location of course.
Old June 29, 2012, 11:43 AM
The next gen Piledriver CPU's will support your AM3+ socket, but until tech sites get a hold of one to officially benchmark (post NDA), I wouldn't hold my breath in regard to a noticeable performance increase over Bulldozer. AMD didn't drop out of the battle with Intel on the high end for no reason. Just sayin.
Old June 29, 2012, 12:34 PM
I'm assuming you're running a Phenom II 955 at stock clocks of 3.2GHZ? If so, you won't see any major differences going to bulldozer. Certainly not worth the $200 upgrade price to go to the 8120. If you go with the 6100 or lower, you may actually notice a decrease in performance, possibly substantially so with the 4100. I think your best bet is to buy a good cooler (H80) and try to overclock that sonofabitch to 4.0GHZ.
Old June 29, 2012, 12:55 PM
BigPhatPaulie's Avatar
X2 on what abyss said. The bulldozers aren't a improvement on the equivalent phenoms so just keep what you have and either OC it or wait to see if PD is any better like it should be
FOR PONY..... that is alll
WIP Cheers , and thanks for all the good times.... BrainEater Case Mods, Worklog & Gallery 10 October 9, 2011 01:15 PM
Somone kill me I think I just wanted a Thuban... ToXic Off Topic 18 December 7, 2010 12:01 AM
Cheers from Fernie BC !! BrainEater Off Topic 66 November 27, 2008 07:06 PM
What are the Ranks on the forum cheers Dashock Off Topic 9 May 1, 2008 04:48 AM
