Originally Posted by Arinoth IF you're looking for an HTPC or a carputer you either want to be going with an Atom processor/board combo (from intel) or an A4/A6 from AMD as those are specifically targetted for low power consumption. My htpc is an A4 (or is it A6) E350 which uses hardly any power whatsoever, hell it uses soo little power from my 150W power brick that when I lost power the unit never turned off as the brick had left over juice for the second my power was down. |
Sorry, don't mean to sound like a dick but can you clarify your response a bit? the E350/450 was what I was looking at originally which AFAIK is not the same as the A4/A6 chips. I was initially considering the E350's because of the LOW power usage. If it ends up as a HTPC I want it fully passive cooling and if it goes in the car then every watt counts. The recearch i've been doing on the A4/A6 shows very average (for a standard PC) power consumption of ~90W idle and ~170W loaded.... that wont satisfy either of my requirements and it doesn't sound like your situation at all. I know when I was looking into it earlier that the E350's were much better than the atoms for minimal extra power usage and the i3 'T' series were again much more powerful than the e350's for minimal extra wattage. I think most of what I read put average total system usage at around 30W or so.
I'm not sure if I'd be asking too much of a little e350/450 but if it goes in the car then it'll be playing music, running a GPS, recording a dashcam, and possible other duties.
