Old June 19, 2012, 02:46 AM
Default how to stability test my cpu?
hey guys, i want know what program i should use stability test my cpu on and how long it should run in program?
i have a 3570k at stock first i want to test if the processor is stable at stock because i have had some problems with the pc in the past so i wanted to be sure it is not the cpu
and then i am thinking about using asus auto tune and then stability test
so what program should i use? and at what settings?
Old June 19, 2012, 04:27 AM
bigFOIG's Avatar
Try Prime95. I would use the small FFTs setting on Prime95 to test stability of the CPU.
Old June 19, 2012, 05:00 AM
maverick_brent's Avatar
Should let it go a minimum of 12hrs ...24 being optimal ..
Old June 19, 2012, 05:46 AM
is it true what he say from 4.00 to 4:33 about damaging your cpu
link:Newegg TV: Ivy Bridge Overclocking Guide with ASUS for Intel 3rd Generation Core CPUs 3770K Z77 1155 - YouTube!
Old June 19, 2012, 07:37 AM
dandelioneater's Avatar
I think that there were concerns about potential degradation from using LinX or Prime95 as they push the chip hard and heat could be an issue. I would use AIDA64 or OCCT to be safe.
Old June 19, 2012, 07:45 AM
gingerbee's Avatar
i used aida64 on my ivy bridge and you can see a clear difference in the heat out put there's my 2cents XD
Old June 19, 2012, 08:17 AM
"Quote This..."
Ummm, no. Why in the world would anyone think you need to pass 12 hours of a synthetic torture test to prove real world reliability?
When I am overclocking all I need to do is get through 2 iterations of the torture test. If no errors pop up in any thread my system has always been stable, no crashes ever.
Old June 19, 2012, 08:20 AM
what mode do you run Squeetard?
Old June 19, 2012, 08:21 AM
Of all stress test i've used (LinX, intel burn test, prime95, occt, orthos, y-cruncher), IBT at maximum nets me the highest temps and detect errors much faster (not meaning better) than others. I could prime95 for hours when IBT crashes in 30 minutes.
Anyway, for me, nothing is stable unless folding stable!
Old June 19, 2012, 08:27 AM
so how long should for an example run aida 64
Test a network port stability? 3.0charlie Networking 18 February 9, 2012 08:17 AM
Ultra stability test makizeka Overclocking, Tweaking and Benchmarking 23 June 17, 2011 04:42 AM
HDD fails S.M.A.R.T. short test, but passes long test? frontier204 Storage 10 May 19, 2011 04:10 PM
System Stability Test PuB_Evo Overclocking, Tweaking and Benchmarking 9 January 12, 2010 03:01 PM
Programs that can test GPU stability? Silvgearx Video Cards 19 March 11, 2009 08:43 PM
