-   -   Buying Intel 2700K off Craigslist . Any advice? (http://www.hardwarecanucks.com/forum/cpus-motherboards/54692-buying-intel-2700k-off-craigslist-any-advice.html)
Ravenor June 12, 2012 02:35 AM
Hi guys,
I have been in contact with a guy on Craigslist that is looking to sell his sealed Intel 2700K that he won in a contest. He says he has all the information for warranty purpose in case something should go wrong. I thought I might throw this out to you guys for some sage advice on any particular questions to ask or what I should be looking for.
I already asked him why he was not using it and he said he already has a 2600K in his system and doesn't want the hassle of swapping out for minimal speed gain.
Any advice would be appreciated as I have to let him know by June 13.
misterd June 12, 2012 04:27 AM
There's very high chances are it came from the Intel Retail Edge program. You should be fine, but I doubt you will have any warranty.
Bond007 June 12, 2012 03:28 PM
^^^+1. Either way if its a good deal then its a good deal.
LarkStarr June 12, 2012 09:44 PM
As long as it's sealed brah.
trayton June 20, 2012 11:22 AM
Make sure its sealed so you know he didn't fry it doing some suicide overclocks or something. Secondly make sure you make yourself knowledgeable about the retail edge program etc.. I bought 2x 2700K's and then found out while getting the 2nd one that I way overpaid for first one! The 2nd guy actually did give me the reciept and I think he ended up paying $104 for the 2700K or something crazy like that.
rommelrommel June 20, 2012 02:19 PM
I don't see how the purchase price has anything to do with the value. Basically a retail edge CPU is worth whatever that CPU without warranty is worth to you, even if the guy got it for free.
Ravenor June 20, 2012 05:27 PM
Guys, i got it last week, it works fine.
