<~----> Should I reformat? - Hardware Canucks
Old June 3, 2012, 05:22 AM
bvsbutthd101's Avatar
Default Should I reformat?
I filed for an RMA for my FTW3 mobo because SATA 3 wasn't working. Now when I get this new motherboard in, should I reformat windows or is it ok just to plugin and boot?
Old June 3, 2012, 05:35 AM
Avenger212's Avatar
I am a true believer of a clean install when it comes to Motherboard and Graphics drivers. I will recommend you format just to make sure, but that's my personal view.
Old June 3, 2012, 05:53 AM
I was thinking the same thing, even though the drivers are the same for the motherboard, windows doesn't always completely remove old drivers after re installing them.
Old June 3, 2012, 05:57 AM
KaptCrunch's Avatar
First back-up your wanted data from drive or use a new drive to install OS and get all current drivers for your OS to a disk and hardware check firmware updates and update in dos only. then install OS with your current drivers disk you made
Old June 3, 2012, 06:03 AM
Originally Posted by KaptCrunch View Post
First back-up your wanted data from drive or use a new drive to install OS and get all current drivers for your OS and hardware check firmware updates and update in dos only. then install OS
I have everything on my HDD, I usually just install the OS and let windows find all the drivers. Always works out good for me.
Old June 3, 2012, 08:36 AM
wirerogue's Avatar
since it's the same board, you don't really have to do a clean install.
i would boot it up and see what happens first. save you alot of time as well.
i just upgraded from a gigabyte z68-ud3 to z68-ud5. same chipset. some of the integrated peripherals were different. windows detected all the new hardware. works perfect. saved myself hours of reinstall.
Old June 3, 2012, 09:14 AM
Also was thinking that, if I can save the time by not re installing, I will. We'll see what happens. Really don't feel like having to re install all my games and such.
Old June 3, 2012, 09:34 AM
wirerogue's Avatar
the only thing is windows will think it is now installed on a different computer so you will have to reactive it.
Old June 3, 2012, 09:53 AM
Figured that, hopefully it all goes well.
Old June 3, 2012, 05:29 PM
Nodscene's Avatar
If it's the exact same board there is absolutely no reason to reformat and reinstall. Frankly you will just be wasting your time.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
SSD reformat and OS install. Should I have used the OCZ utility? JayDeeHobbit Storage 0 November 5, 2011 05:06 PM
need help with when i reformat my rig pls? Kamran1981 New Builds 6 February 3, 2011 07:28 PM
Unable to reformat pc, error keeps popping up! ezytgr O/S's, Drivers & General Software 11 March 17, 2010 10:24 PM
5970 with 285 benches before reformat gerardfraser Video Cards 7 November 26, 2009 09:57 AM
reformat prob(posting for friend) cmac79 Troubleshooting 19 August 10, 2008 08:45 PM
