-   -   Asus P5QC (http://www.hardwarecanucks.com/forum/cpus-motherboards/54356-asus-p5qc.html)
Nikla16 May 18, 2012 09:33 AM
Asus P5QC
Hi im going to buy new drr3 ram's but im not sure what to buy.
im interested in buying 8gb but some people say that 8gb ddr3 are not supported by this mother board
thanks
dandelioneater May 18, 2012 09:43 AM
Check the qualified memory list on the manufacturers website.
sswilson May 18, 2012 09:44 AM
According to the specs ( ASUS - Motherboards- ASUS P5QC ) it will only accept 4 gig sticks so pick a set that's 2X 4G. The other question would be what OS you're running, if it's not a 64bit OS you won't be able to see/use more than your current 4gb.
Nikla16 May 18, 2012 09:46 AM
i have 64 bit windows so it'll be fine
sswilson May 18, 2012 09:50 AM
QVL doesn't list any 4G sticks, but the specs state 8G max over two slots.....
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory
4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory
Dual channel memory architecture
When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended
*DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots!
**Refer to ASUS or this user manual for the Memory QVL(Qualified Vendors Lists).
*** When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
That's definitely a frankenboard though with both DDR2 and DDR3. I wouldn't be surprised if you have issues getting the memory to run.
Nikla16 May 18, 2012 09:51 AM
its pretty distracting 2x Dimm 8GB im confused
sswilson May 18, 2012 09:54 AM
On that board, DDR3 only has two slots while DDR2 has 4. max of 8G over 2 slots = 4G per stick.
dandelioneater May 18, 2012 09:56 AM
According to the specs, you should be ok to run two 4GB memory modules. But it is kind of an old board so who knows how well it will play with new ddr3 modules.
Something like these may be ok.
Nikla16 May 18, 2012 09:58 AM
i already have ddr3 rams installed on the board but im not sure if it supports 4 gb sticks thats why im asking this question
Nikla16 May 18, 2012 10:07 AM
1 Attachment(s)
this is the QVL they have its been updated in 2008 a bit old
