Old May 16, 2012, 03:06 PM
G777's Avatar
Question Advice on Z77 board for overclocking
So on an impulse I picked up a 3770k on the weekend, and have been using it in the P67 board I already have an asus M4E, using the newest bios.
On water cooling I seem to be hitting a bit of a wall around 5.3GHz, and plan on putting the chip under a ss phase unit in the next few days.
A couple questions:
-would a Z77 board provide better overclock-ability than my m4e?
-I've narrowed the board choice down to two that are available locally to me fairly easily, the asus maximus v gene for $190 or the gigabyte z77x-ud5h at $182.
Thoughts?
Old May 16, 2012, 03:40 PM
SugarJ's Avatar
1. Probably not. I'd tend to think the overclock would be driven more by how good your power circuitry is on the mobo. The main difference between Z68 and Z77 is the native USB3, as far as I can see.
2. The Maximus would be my choice out of the two.
I think I'd stick with my Z68 rather than spend $200 on a minimal impact upgrade.
Old May 16, 2012, 03:59 PM
G777's Avatar
It's the P67 version I'm using so there are some other small differences, but good points.
I've had a hard time finding any info on overclocking ivy bridge cpu's on P67 vs Z77... though after posting the same question on OCN I understand the max multi is lower than on Z77 boards; though not enough to make a difference unless you're using ln2
Old May 16, 2012, 04:28 PM
crazyea's Avatar
If you just have to, and I know how that feels, then yeh the Maximus V Gene is what I would chose as well.
Old May 16, 2012, 05:05 PM
Stosh's Avatar
agreed. unless you're doing some really big number crunching or rendering, whatever, you're not going to notice the difference by going a few ghz higher.
Use the spare money for a 1tb raptor backup drive.
Advice on a cheap(ish) 775 board Brian CPU's and Motherboards 2 June 4, 2010 10:33 PM
overclocking Striker Extreme 680i board Zipper07 Overclocking, Tweaking and Benchmarking 0 July 14, 2009 07:24 PM
best overclocking phenom budget board trt740 CPU's and Motherboards 9 February 16, 2009 09:46 AM
Planning on overclocking Q6600 soon, need a little advice Matt Overclocking, Tweaking and Benchmarking 25 January 26, 2009 12:19 PM
Overclocking the Q6600 on an nForce 650i board Menello Overclocking, Tweaking and Benchmarking 3 August 20, 2008 11:29 PM
