Originally Posted by gingerbee wow what are you cooling with those are looking off unless your on water and your house really cold those temps seem off check realtemp |
Realtemp and the Bios read the same temperatures.
I'm running an A70 with both fans in a push configuration, and a third fan blowing through the heatsink to 2 exhaust fans. It maximizes static pressure inside the heatsink for improved cooling.
The cores hit just over 50 Celcius in Intel Burn test at 4.2 Ghz, 1.15 volts in the bios. I'm starting to think that the CPU die is so small, and the direct touch heatpipes so large that that core is somehow hitting a dead zone in the base of the heatsink. I may try to flip it 90 degrees and see if that helps when I get my new Cougar fans on Tuesday.
