Originally Posted by W4ff1e My 2500k's @ 4.3ghz (99.5x43) right now, its heading into winter over these parts so ill scale up as i go, ive got an h60 not even running @ 100% (hdd scratch noise comes in when I dont run it off a PWM header) and im hitting max 57C @ 1.284v.
My room temp is ~22C atm.
Just a thaught, what if i put my pc up the the window and set the fans so i drew air in from outside, atleast at night i would get some pretty good temps, but would there be more dust outside or in? |
When it is cool outside, I open 2 windows within 6 feet of my computer, then have a box fan blowing in my case(don't use a side panel on my PC case) 64-66C load temps while folding with a stock GTX 480 are pretty damned good.
